Can I add a 2" body lift to my 3" suspension lift and not have problems with the VSC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blue86gt, Aug 10, 2011.
  1. Aug 10, 2011 at 8:26 PM
    blue86gt
    blue86gt [OP] Active Member
    Vancouver Island - Qualicum Beach
    2010 Tacoma - TRD Sport - Black
    3-inch suspension lift
    I have a 2010 Tacoma with a 3" suspension lift. I know there are problems with the VSC with a 6" suspension lift. Since the VSC censor is mounted to the engine and a body lift doesn't lift the engine... would a 2" body lift cause problems with the VSC?
    Thanks
  2. Aug 10, 2011 at 8:28 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
  3. Aug 10, 2011 at 8:43 PM
    blue86gt
    reset VSC?
  4. Aug 10, 2011 at 8:48 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Bigger isn't better. Anything over 3" is over kill, but it's your truck so do what you want.
    Also, your VSC will still be screwed up. I know this because Christian just said it. :woot:
  5. Aug 10, 2011 at 8:55 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Reset the VSC
  6. Aug 10, 2011 at 9:05 PM
    OZ-T
    Peter North
    British Columbia
  7. Aug 10, 2011 at 9:21 PM
    blue86gt
    I'm in Qualicum/Parksville
  8. Aug 10, 2011 at 9:23 PM
    OZ-T
    Peter North
    British Columbia
    I'm in the Gulf Islands
    Are you having issues with your VSC engaging ?
  9. Aug 10, 2011 at 9:29 PM
    blue86gt
    It's fine so far, but I want to go bigger than 3" lift and I'm told that the VSC will engage
  10. Aug 10, 2011 at 9:31 PM
    OZ-T
    Peter North
    British Columbia
    Probably .
  11. Aug 10, 2011 at 9:52 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    There is nothing wrong with a bodylift depending on how you use your truck. Likewise depending on how you use your truck a bodylift can be a bad idea. Like others have said you can re-calibrate the vsc but you may also get lucky and find you have no problems. Either way its not a big deal.
  12. Aug 10, 2011 at 9:56 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    How does a body lift affect VSC im curious or any type of lift for that matter???
  13. Aug 10, 2011 at 10:06 PM
    OZ-T
    Peter North
    British Columbia
    He's talking about stacking a body lift on a suspension lift .
    The VSC is activated because the truck is more top heavy in turns etc , triggering the yaw sensor into thinking the truck is getting into a rollover or fishtailing condition .
  14. Aug 10, 2011 at 10:13 PM
    Gincoma
    Salt Lake City UT
    That makes sense....learn somethin new
  15. Aug 10, 2011 at 10:14 PM
    OZ-T
    Peter North
    British Columbia
    It happens occasionally in my truck still
