Can I change flush it, leave it, or drain and fill?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nazareth7, Dec 17, 2024.
  1. Dec 17, 2024 at 11:46 AM
    Nazareth7
    Nazareth7 [OP] Well-Known Member
    2007 Tacoma 2x4
    Hello beautiful community
    So my Tacoma didn’t have transmission fluid replaced for a long time, nothing wrong with my transmission it shifts smooth and runs good. Should I change flush it, leave it, or drain and fill? Mileage is 210k .
  2. Dec 17, 2024 at 11:47 AM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Drain and fill.
    knottyrope likes this.
  3. Dec 17, 2024 at 12:23 PM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    You will find this discussed a lot here on the forums. A general consensus is that in a case such as yours, if after 200K miles the fluid has never been changed, then don’t touch it. if it has been serviced a time or two, then doing a couple of drain and refill operations should be OK. It is a good idea to drain the fluid, drop the pan, and inspect the magnets and see what’s in the bottom of the pan and pick up screen. If there’s a lot of goop, that’s probably clutch material, and you don’t want to take that out of the system.
    I suggest you track down some of the older discussions about this and read up on it. There are a lot of opinions. A flush is probably not worth the risk it represents, again, assuming that the transmission has not been serviced much (if any) before.
    TheTaco09 likes this.
  4. Dec 17, 2024 at 12:35 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Mine had 135K last year and hadn't been done. I did a drain/fill. No way I'd flush even if it was newer.
    Dbarffish likes this.
  5. Dec 17, 2024 at 12:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Short answer is : Dran & Fill
    Longer answer: Drain, Drop pan, clean pan and magnets , new filter, and refill.
    Longer Answer : All of the above with a flush. But only if the flush is done correctly.
    You never want to perform a flush with old fluid.
    You only want to send new clean fluid down the system to flush it.
    Also FWIW. If your truck has the tow package.
    You can do a flush yourself. It’s a bit of a task and slow.
    But the ATF cooler makes a great “flush” point.
    DIY here. (I never done. Don’t intend to)
    https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/
  6. Dec 17, 2024 at 12:58 PM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    I did the DIY full flush back in April, 10k miles later and no issues have arisen. I think that it was the first transmission service for the truck, and it was at 203k miles at the time.
  7. Dec 17, 2024 at 1:33 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Save your money, drive it until it dies then rebuild it. Changing it now won't prolong when it needs to be rebuilt. Chances are good it'll go another 100,000-200,000 miles if left alone.
    a400ryan likes this.
  8. Dec 17, 2024 at 1:53 PM
    TnShooter
    Deogee
    STOCK
    I don’t see anything wrong with the DIY procedure.
    I am just going to stick with 50k drain and fills. Maybe sooner depending on the situation.
  9. Dec 17, 2024 at 1:54 PM
    ThePositiveWay
    SE Tennessee
    If I had been more on top of things, that would have been my plan as well. Wanted to get as close to a clean slate as I could and start doing the 50k cycle.
    TnShooter likes this.
  10. Dec 17, 2024 at 2:00 PM
    zguy1
    zguy1 Well-Known Member
    Midwest
    My truck had no known history of the trans being serviced. I did a drain and fill at 226k. Actually I did several back to back. I also did a drain and fill at 295k. I'm at 330k now.
    10thMTNgrunt and jackn7 like this.
  11. Dec 17, 2024 at 4:20 PM
    Waasheem
    Waasheem
    2007 xrunner
    I made the mistake of replacing the fluid in a transmission that hadn’t been regularly serviced, once the clutch material wasn’t in there it slipped horribly.
  12. Dec 20, 2024 at 3:45 AM
    erekv2
    erekv2 Member
    Erick
    2006 TACOMA XSP
    NONE
    Need some advise on this same topic, 2006 Pre-runner, Currently @ 194K, I have never messed with Transmission oil change on a regular basis but I am having an issue where I am not able to get into 4th Gear. what are my options. My wife said that it had a check engine light, while I was gone on a work trip for about 2 weeks and now its not showing up. I am thinking of taking it to auto zone to get a code reading even if its not showing anything to see if something comes up.
    But on the mechanical side, what are my options?
    A. open up "overflow plug" to see if anything comes out, if not add Toyota AT Oil, until refilled?
    B. Drain and fill the transmission fluid, Basically a simple transmission oil change?
    I will keep looking into issue but I would like your feedback if you dwelt with something like this.
    Thanks !
  13. Dec 23, 2024 at 11:39 PM
    Nazareth7
    2007 Tacoma 2x4
    Get a bluedrive scanner , it connected to your phone via app. And it’s great way to see live data etc as well. It costs about 100$ or less .
  14. Dec 23, 2024 at 11:41 PM
    Nazareth7
    2007 Tacoma 2x4
    Am I on the safe side if drain and fill only ?
  15. Dec 24, 2024 at 6:59 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Yes, and something else to consider is multiple drain and fills, how ever many times you want, I would recommend 4 minimum.
    and then in a few weeks do another 4, that way you’re replacing much of the old fluid without forcing anything through the lines/system in an overly aggressive way.
  16. Dec 24, 2024 at 7:14 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Around 250k I did a drain and fill when my rpms went high on take off and they went back down after doing a dump n fill.
    cant hurt to do it twice for more good ATF
  17. Dec 24, 2024 at 8:34 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I would vote for the drain and fill, new filter, gasket and a few quarts replaced.
    At the very least, you'll verify you're at the right fill level.
  18. Jul 5, 2025 at 10:56 PM
    Nazareth7
    2007 Tacoma 2x4
    Did you flush it or just drain and fill?
  19. Jul 6, 2025 at 5:34 AM
    Tacologist
    Tacologist Well-Known Member
    Bob
    Tenessee
    05 Double Cab Shortbed
    Rear leaf suspension. Home done tailgate re-inforcement.
    This is a well known condition that takes place in unserviced transmissions when people replace the fluid in high mileage conditions. The clutch particles act as gripping agent that now gets flushed out leaving worn clutch plates that will slip.
