can i clear 33s?
Discussion in '1st Gen. Tacomas (1995-2004)' started by DAMNDUKE, Aug 12, 2011.
  1. Aug 12, 2011 at 3:26 AM
    DAMNDUKE
    DAMNDUKE [OP] Member
    Duke
    albany ny
    2002 sr5 tacoma
    2.5" spacer lift, K&N intake.
    hey i currently have a 2.5" spacer lift with what i think is an aal, i just ordered these bad boys: also bought the 1" diff drop kit, (neither are installed yet)
    i was wondering if i can clear 33s with out trimming anything? what width tire should i go with? i have 17 inch american racing wheels. my taco is more of a road puppy, i only take it in the woods once in a while.
    thanks for the help.
  2. Aug 12, 2011 at 3:36 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    The simple answer is NO... unless you enjoy rubbing
    3" or less will have some sort of rubbing at some point during the cycling of the suspension and/or steering
    the most common problem areas is the cab mount, mud flaps, and all that plastic fender liner...
  3. Aug 12, 2011 at 3:51 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this^^^^^^^^^^^^
  4. Aug 12, 2011 at 4:05 AM
    DAMNDUKE
    Duke
    albany ny
    2002 sr5 tacoma
    so what would i need/ have to do to clear 33s? how much more lift would i need on top of the 3" suspension? body lift possibly? not big into body lifts, might just end up sticking with a 32.
  5. Aug 12, 2011 at 4:23 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    you must cut some and cut some more:D
  6. Aug 12, 2011 at 5:28 AM
    snoozeworm
    snoozeworm taco king
    wheeling,wv
    2004 regular cab 4x4 5 speed
    Extra leaf springs in rear Pioneer head unit fj cruiser wheels 1in coil spacers siren
    I have 33's (285-70-17) or (32.8x11.5) with a 1 inch spacer lift up front and a 2 inch leaf spring lift in the rear. They clear just fine, the only time they rub is at full lock going into a parking spot on a rare occasion, and that is frame rub so even if i had more lift i think that would still happen.
  7. Aug 12, 2011 at 10:22 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wheel spacers would help get rid of the frame rub.
    OP can also get new rims with a different backspacing to help avoid frame rub.
    Either way..your going to have to trim some if you want to offroad.
  8. Aug 12, 2011 at 10:27 AM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    x2 you should be fine! 2nd gen guys dont what their talking about, jk. 2nd gens would need more lift but i think youre good
  9. Aug 12, 2011 at 10:27 AM
    04taco2wd
    04taco2wd Take your flame, ignite the world!!!!
    Colby
    Southern Pitt,NC
    06 AC 4x4 SR5
    6" Fabtech Lift, Custom bedside decals, ICON C/Os, 17x9 Cruiser Alloys, 33x12.5x17 Coopers, UWS Lopro Toolbox, more to come...
    Stick with a 265/70/17 if you dont wana trim. Otherwise, look into a 255/85/17 (I think thats right). It is a 33 but narrower so it doesnt rub as bad.
  10. Aug 12, 2011 at 10:27 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Depending on what size of 33s you get, you will most likely rub the UCAs as well as the frame and inside the fender well. The rubbing should be minor after you clear the UCAs. Wheel spacers/adapters or different wheels would help with the UCAs and frame. Trimming the plastic inside the wheel wells and doing the pinch weld mod will help a lot. Those coilovers are nice by the way, I'm running them on my truck :D
  11. Aug 12, 2011 at 10:29 AM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
  12. Aug 12, 2011 at 10:31 AM
    DWreck
    Derek
    Las Vegas, NV
    I have 33.1" tires with a 4.5" backspace wheel. I barely rub the bottom of fender flare.
  13. Aug 12, 2011 at 10:34 AM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    nice rig man. im diggin the wheels, pro comp?
  14. Aug 12, 2011 at 11:08 AM
    DWreck
    Derek
    Las Vegas, NV
    Yes, 7089
  15. Aug 12, 2011 at 11:30 AM
    99yodataco
    99yodataco Little Taco that could
    Chad
    New Mexico, it's just a little bit fresher.
    MGM 21 TRD OR 6sp MT
    Soon...
    I have 33/12.5R15's on my truck do the pinch weld mod with a BFH, no need to trim.
  16. Aug 12, 2011 at 12:49 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    I have a 2.5 inch spacer up front and my left front 33 rubs at full turn to the left on the cab. I had to trim about 6x6 inches worth of fender liner on both sides, I also beat in the part of the fender that sticks out...
  17. Aug 13, 2011 at 2:15 AM
    DAMNDUKE
    Duke
    albany ny
    2002 sr5 tacoma
    awesome thats what i was looking for. im going to go with the same size tire: 285-70-17 im looking at the bfg mud terrain km2s :D if they do rub on the frame then i will buy wheel spacers but if you dont have any problem running them then i shouldnt either.
  18. Aug 13, 2011 at 3:09 AM
    DAMNDUKE
    Duke
    albany ny
    2002 sr5 tacoma
    I cant wait till the coilovers come in! what do you have yours set at and what size tires are you running? im going to go with 285-70-17. i also bought the diff drop kit to because my cv boots are ripped on both half shafts. i hope the drop will prevent them from ripping again.
  19. Aug 13, 2011 at 3:20 AM
    DAMNDUKE
    Duke
    albany ny
    2002 sr5 tacoma
  20. Aug 13, 2011 at 8:14 AM
    Tacoma mud
    Tacoma mud Well-Known Member
    Kyle
    TEXAS
    97' xtra cab sr5 4x4
    soon to come
    Your gonna have to trim... If you get a good BS with a wheel spacer you should be good
