Can I cross water?
Discussion in 'Off-Roading & Trails' started by monsterkx2fiddy, Oct 21, 2012.
  1. Oct 21, 2012 at 2:45 PM
    monsterkx2fiddy
    monsterkx2fiddy [OP] Well-Known Member
    Birthplace of Davy Crockett
    Well I did the rear differential breather mod the other day. My question is can I go through water mud? Also the write up for differential breather says it came in through his axle seals?
  2. Oct 21, 2012 at 2:46 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Stop worrying about it, you'll be fine. And if you are that paranoid change the fluid more to see if there is water in there.
  3. Oct 21, 2012 at 2:47 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Define "water"
  4. Oct 21, 2012 at 2:49 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Water is a chemical substance with the chemical formula H2O. A water molecule contains one oxygen and two hydrogen atoms connected by covalent bonds. Water is a liquid at temperatures above 0 °C (273.15 K, 32 °F) at sea level, but it often co-exists on Earth with its solid state, ice, and gaseous state (water vapor or steam). Water also exists in a liquid crystal state near hydrophilic surfaces.[1][2]
  5. Oct 21, 2012 at 2:49 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    A liquid composted of hydrogen and oxygen :D
  6. Oct 21, 2012 at 2:50 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    That's about enough outta you! Go to your room!!!
  7. Oct 21, 2012 at 2:57 PM
    joes06tacoma
    Joe
    Central Coast, CA
    How much water we talking about?:D I've driven several trucks through water above the hubs without any failure. Any deeper than that, I'd start looking to waterproof things.
    Don't hit a body of water at speed, that's asking for it. Keep it slow and steady and you shouldn't have a problem, unless you're trying to cross something that would be better traveled by boat.:eek:
  8. Oct 21, 2012 at 3:01 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Good good, class now define now define the fire tetrahedron. And all of its components.
  9. Oct 21, 2012 at 3:04 PM
    4x4jeep
    Kyle
    Destin FL.
    The fire tetrahedron represents the addition of a component, the chemical chain reaction, to the three already present in the fire triangle. Once a fire has started, the resulting exothermic chain reaction sustains the fire and allows it to continue until or unless at least one of the elements of the fire is blocked. Foam can be used to deny the fire the oxygen it needs. Water can be used to lower the temperature of the fuel below the ignition point or to remove or disperse the fuel. Halon can be used to remove free radicals and create a barrier of inert gas in a direct attack on the chemical reaction responsible for the fire
  10. Oct 21, 2012 at 3:13 PM
    MontanaTaco
    Colter
    14 DCLB Sport
    OME lift
    Gotta love wikipedia
  11. Oct 21, 2012 at 3:15 PM
    monsterkx2fiddy
    Nothing to deep. Never enough to go in my
    Doors. My range r I never worried. for being such a capable truck I hate taking so many our precautions. Maybe its just me
  12. Oct 21, 2012 at 11:06 PM
    x2468
    x2468 Well-Known Member
    Tallahassee
    '02 TRD 4wd V6 Xcab Sr5
    Do you have 4wd? I ask because one that makes it easier to go through more water and two, you mentioned you did the rear diff breather but you could also raise the front one.
    I would also recommend doing the transmission breather, and i think the t-case has a breather.
    If you're not going above the doors you don't really need to worry but.... sometimes you go deeper than you wanted to by accident.
  13. Oct 21, 2012 at 11:09 PM
    TnRedNeck721
    TnRedNeck721 GO VOLS!
    Zach
    TN
    07 TRD off road 4WD
    ok mr fire man you may stop this now. we know you play with fire and water.
  14. Oct 22, 2012 at 12:57 AM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Front is raised already.
    Water sucking in through the seals is because of the stock breather, the new one needs to be able to breathe -- in and out -- or you'll create a vacuum (when you drastically change the temperature -- cool water crossing, hot axle) in the housing and it'll suck in from wherever if it can.
    So you raise and change the breather so it can free flow -- in and out -- and from a clean dry place.
    I'd stay below the bottom of the transfer case if you can.
  15. Oct 22, 2012 at 1:06 AM
    the.sight.picture
    the.sight.picture Well-Known Member
    Nick
    Warren County VA
    2016 MGM TRD OR 4X4 DCSB
    Tint
    google:rolleyes:
  16. Oct 22, 2012 at 1:12 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  17. Oct 22, 2012 at 2:20 AM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    also OP. where all you going off road?
