Can I Drain and re use my transmission oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lordviews, Oct 1, 2022.
  1. Oct 1, 2022 at 11:15 PM
    lordviews
    lordviews [OP] Well-Known Member
    07 TRD Sport
    So basically about a week ago I did a drain and fill while replacing the filter as well thinking that’ll completely fix my shutter issue but it’s still there. Less rigorous but it’s there. I think a full drain will probably be better and I was wondering if the oil I just put is recyclable as it’s only been in for a week? Like can I still use it? Haha it was pretty pricey so I’m always interested in saving a buck or two. Honestly my last resort is to just use some instant shudder as there’s a lot of mixed opinions about it on here.
  2. Oct 1, 2022 at 11:31 PM
    Tyler7544
    Tyler7544 Well-Known Member
    L
    The most unique and special Tacoma
    Nah dude. There is no way to keep contamination out of oil once you drain it, and you’ll just introduce all that crap into your transmission. A new transmission is a bit more expensive than new fluid.
    Alexely999 likes this.
  3. Oct 1, 2022 at 11:36 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    If the shutter lessened having done a drain and fill which I believe is maybe a third or less of the total fluid, a complete DIY flush would be worth it in my opinion. Easy to do, done it myself, I know it’s not cheap but nothing done right is, relatively speaking that is, best of luck. Dig through the forum, there’s a few step by step right ups on a complete flush.
  4. Oct 2, 2022 at 12:13 AM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    I get where you are coming from but, as noted above, just change it...
  5. Oct 2, 2022 at 4:50 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    I’d try Lube Guard
  6. Oct 2, 2022 at 9:48 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I wouldn’t, your new fluid is mixed with the old. You have to do about 3 drain and fills to get all the “old” out.
    When you drain the fluid from the pan, you don’t get all of it out. There is still A LOT left in the converter and cooler lines (if you have them)
  7. Oct 2, 2022 at 9:49 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    x2 and I would recommend the garden pump sprayer method
