Can I drive my truck w/o driveshaft?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nelz1, Apr 1, 2013.
  1. Apr 1, 2013 at 10:07 AM
    Nelz1
    Nelz1 [OP] Well-Known Member
    Boston
    07 Tacoma DC TRD - 20 Tacoma DC off road
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    In an effort to troubleshoot a vibe/hum sound I want to rule out the carrier bearing and any u joints heading to the rear axle.
    SO I thought withought the drive shaft in place can I run the vehicle in 4WD high and see if the symptoms dissapear :confused:
    Dont know if the drivtrain can handle it but if I could do it, it would isolate a bunch of compnents at once???
    Thanks,
  2. Apr 1, 2013 at 10:08 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    April fools... I get it.
  3. Apr 1, 2013 at 10:09 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    That's retarded, but yes. People have limped their trucks back on fwd before. I think Jason had to do it when he fucked up his back axle. It's not a good idea though
  4. Apr 1, 2013 at 10:09 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    X2
  5. Apr 1, 2013 at 10:10 AM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    I thought you were serious for a second.
  6. Apr 1, 2013 at 10:48 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    Yes.
    This is actually part of the written Toyota technical procedures for troubleshooting
    various vibration issues in order to isolate problems. truck will drive fine on front wheel drive only,
    just don't carry any loads or tow anything. don't leave it disconnected longer than
    necessary to isolate problems.
  7. Apr 1, 2013 at 10:52 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Completely fine. I don't understand why everyone is saying it's bad. You can even safely make tight turns on pavement without the rear driveshaft in place.
  8. Apr 1, 2013 at 10:58 AM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    agreed. there are no issues removing rear driveshaft and running in 4Hi to troubleshoot.
  9. Apr 1, 2013 at 11:07 AM
    Nelz1
    Boston
    Thanks for all the input!!!!
  10. Apr 1, 2013 at 11:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, perfectly fine as long as you don't make a habit out of it and a good way to isolate a vibration problem.
  11. Apr 1, 2013 at 11:16 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Make sure you mark your driveshaft and u-joints before you remove it.
