Can I drop a 2018 tacoma 4 x4 engine in a 1991 4x4 pickup
Discussion in 'Toyota Trucks & SUVs' started by Gusscrazybass, Jul 10, 2022.
  1. Jul 10, 2022 at 8:49 AM
    Gusscrazybass
    Gusscrazybass [OP] New Member
    Gus
    1991 Toyota Pickup 4x4
    Anyone know if this could be done? Looking to drop a 2018 tacoma 4 x4 engine in a 1991 4 x4 pickup. I'm new to my truck and slowly learning. Also any good mechanic shops in southern California that know a lot about 1991 pickups
  2. Jul 10, 2022 at 1:49 PM
    eon_blue
    Azusa, CA
    I wouldn't want to, all the additional wiring a modern engine would need in an older pickup would be a huge headache for little reward. Would rather look for a 3.4l v6 out of a 1st gen Tacoma or 4runner (or T-100/1st gen Tundra)
    3.4 swaps into Pickups are very common
  3. Jul 10, 2022 at 3:45 PM
    Gusscrazybass
    Gus
    Thanks i figured
  4. Jul 10, 2022 at 3:48 PM
    eon_blue
    Azusa, CA
    Would be the issue of mating it up to your transmission too, if it's an auto these new engine/tranny combos have so much computer control you'd have to source the transmission from a 2018 as well I'd bet. Just seems like it would be more trouble than it's worth if it's even possible.
    3.4s are much more common to swap into those pickups and you could find a ton of write ups and info out there on how to do one of those swaps
    Gusscrazybass[OP] likes this.
  5. Jul 28, 2022 at 4:11 PM
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    I put a 4.7 Tundra drivetrain in a 1996 T100. Functioning heat and AC.
    End product was also 100% California BAR smog certified.
    And, I wouldn’t do it again, if that tells you anything.
