Can I enlarge the center bore on steel rims by 7mm?
Discussion in 'Wheels & Tires' started by shitty, Nov 26, 2020.
  1. Nov 26, 2020 at 8:37 PM
    shitty
    shitty [OP] New Member
    I have a 2001 2wd 2.4l 15 inch rims. I recently purchased snow tires on 5 lug 16 inch toyota rims off a 2014 2wd 2.7l. Oem wheels, good tires, great price! What could go wrong?
    I didn't realize center bore was even a thing but sure enough, even though all the other dimensions are the same, the newer rims have a 7mm smaller hole in the middle and don't fit...
    I've done some research but it seems all the other people that have had this problem don't have nearly as much metal to remove and/or have alloy rims. What would be the best way to remove 3.5mm of steel around the radius of the hole while keeping it concentric?
    I was thinking a hole saw with some sort of homemade arbor? I'm sure the best thing would be to take the rims to a machine shop but I don't have the time or money for that.
    Any thoughts would be much appreciated!
  2. Nov 26, 2020 at 8:53 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  3. Nov 26, 2020 at 9:06 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You're prob. just better off to paint your old wheels and remount them.
    The truck needs that area for support so 1/2 assing it is not a good idea. That said, back when I was young and wheels were lug centric we thought nothing of driving 100 mph on broken studs.
  4. Nov 26, 2020 at 9:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Since you said, “Any thoughts would be much appreciated”
    My thought is “Do not do it”
    Just trying to keep you safe my friend:thumbsup:
  5. Nov 26, 2020 at 9:16 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    7mm is a bunch doing it at home by hand.
    I'd use machine shop. Even a rotary tool is going to be a LOT of grinding x4.
  6. Nov 27, 2020 at 5:24 AM
    3r3Taco
    3r3Taco Well-Known Member
    So.Cal
    17 SR5 DCSB
    Factory Stock
    Carbide tip router. Se the dept properly. Then go to town. Shouldn't take long to do.
    Not my picture but i have done this.
  7. Nov 27, 2020 at 5:30 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Something best done by a machine shop, negating any cost savings. In a zombie apocalypse sure go for it. Otherwise back away from the keyboard and nobody will get hurt.
    Does this count as a Friday thread?
    $yoda$ likes this.
  8. Nov 27, 2020 at 6:04 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There are hub concentric wheels and you are talking 1/4 of an inch +, far cheaper to sell them and get the proper wheels. Hub concentric and lug concentric makes a big difference use the proper wheels.
  9. Nov 27, 2020 at 6:40 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Machine shop. 100%.
    They would likely center on the lug holes, assuming the 3.5 mm cut doesn't intersect these holes.
    Best option is to sell them on. Hunt for the correct wheel with all matching fit dimensions.
