Can I fit 33x12.50's with this amount of lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madams, Aug 9, 2011.
  1. Aug 9, 2011 at 3:03 PM
    Madams
    Madams [OP] Well-Known Member
    South Carolina
    They call it barney
    I got a 2" toytec aal and its been on there for about a month and a half. I just measured from the ground to the top of the rear fender well and I am thinking about getting 33x12.50r15 duratracs, right now I got 31's. It measured around 38". Will i be able to fit 33's in the rear without it looking really stuffed. I like it stuffed but not so stuffed the rear when i go offroad it will be rubbing at the back of the fender well ( where the tire is the closest to the fender well. On the bumper end). Im not worried so much about the front cause I got 5100's and eibach springs.
  2. Aug 9, 2011 at 3:38 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
  3. Aug 9, 2011 at 3:38 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    Front is what you should be worried most about, because you would only rub when you turn. I have 2.5 inches of suspension lift and I have 33's with some trimming. And even then my left tire rubs at full turn to the left.
  4. Aug 9, 2011 at 3:47 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Parker
    Birmingham, AL
    04 taco 4x4 TRD Debadged
    Shrockworks front bumper Shrockworks sliders Tacoma sport rims painted grey 285/70/17 BFG KM2 AEM cold air intake Grey wire mod Donahoe/Icon coilovers 4crawler 1'' BL CBI cutbed rear bumper Bud-Built skids Inchworm e-locker skid
    Just cut some if it rubs. You might rub the frame on full lock, no biggy.
  5. Aug 9, 2011 at 4:47 PM
    Madams
    South Carolina
    They call it barney
    The other 95.5 have 3 leafs stock, right? I bought mine used and it was stock and it had 2 leafs. Hopefully its not a mistake by the toyota place or something happen to the 3rd leaf by the first owner.
  6. Aug 9, 2011 at 5:53 PM
    Madams
    South Carolina
    They call it barney
    Talking about the rear. I have 2" toytec aal in the rear and dont want to make the 33x12.50 duratracs looked bad stuffed in the rear.
  7. Aug 9, 2011 at 6:05 PM
    PcBuilder14
    Brent
    Las Vegas, Nevada
    2003 Tacoma TRD 4X4
    My rear leafs only have a 1.5 inch add a leaf and they look like the pic in my sig...
  8. Aug 9, 2011 at 6:47 PM
    Big M
    Big M Well-Known Member
    Central Connecticut
    02 TRD xtra cab 3.4 5spd
    bilstein RCD 5100's all around, eibach coils, rear add a leaf, diff drop, cb drop, 33x12.5x15 tires, HID headlights, pioneer mp3 head unit, 12" sub with mono amp, grey wire mod, 2-low mod
    Im running the same lift as you with 33x12.5x15 and the tops rub the bottom of my flares when its flexed to the max, does not touch the rear of the fender at all. like PcBuilder14 said the fronts are a different story, I had to lose the front mud flaps cut the insides of the flares up and do the pinch weld mod, no full lock rub as I have 2" spacers. Go for it....
  9. Aug 10, 2011 at 5:23 AM
    Madams
    South Carolina
    They call it barney
    Whats the measurements of your rear. Mine is 38" maybe below just a hair.
  10. Aug 10, 2011 at 9:32 AM
    Big M
    Central Connecticut
    mine is 39.5" from ground to center of fender
