Can I Fit These Tires Under this Lift?
Discussion in 'Suspension' started by dysfunctnlretard, Jun 29, 2009.
  1. Jun 29, 2009 at 3:40 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2021 Jeep Rubicon
    Im ordered some Billy 5100's for all four corners from DSMS today, I have yet to pay for the order via paypal. I am debating whether I should also add on the Fabtech 1.5" AAL to my order. My ultimate goal is simply a level truck with some 285/75/16 tires. Will I need the AAL for the tires or will they fit fine?
  2. Jun 29, 2009 at 4:14 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    the main issue is that there will be a lot of trimming to fit those in the front. roxspin72 put those on his w/ those tires and a lot to trim. not only that, but if you are planning on running those on stock rims, u'll need either spidertrax wheel spacers to avoid the UCA or aftermarket UCA's
  3. Jun 29, 2009 at 5:00 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    So I'll still need to trim a substantial amount despite setting the front billies at 2.5"?? What about the rear?
  4. Jun 29, 2009 at 5:15 PM
    The_Hodge
    SC
    oh yes...a good bit of trimming. i had to trim for that size w/ 3" of lift. still hit the frame every now and then on a tight, flexed turn. the rear i'm not sure, but i'd do the AAL just cuz...that or see if u can get the TSB done for the rear
  5. Jun 29, 2009 at 5:20 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    Allright. Still lookin to get it done but will keep your info in mind. Thanks.
  6. Jun 29, 2009 at 5:29 PM
    The_Hodge
    SC
    i'm not by any means saying its not possible, cuz it is....just lots of trimming. PM roxspin72 and see if he has any pics of all he had to cut out.
  7. Jun 29, 2009 at 5:32 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    I hate to sound like a dumbass but what exactly are the cons of trimming the wheel well?is it just a matter of losing that part of truck?
  8. Jun 29, 2009 at 5:34 PM
    The_Hodge
    SC
    its just cutting/trimming plastic under there. remove mudflaps, cut sections off the fender flares and inner fender, etc
  9. Jun 29, 2009 at 5:44 PM
    dysfunctnlretard
    Manny
    CA
    2021 Jeep Rubicon
    I c. O well. It's worth it imo. How much (ballpark figure) should I be looking at spending just for the trimming?
  10. Jun 29, 2009 at 5:45 PM
    The_Hodge
    SC
    u talking time or money? i wouldnt pay anyone to do shit. all u need is the screwdriver to remove the mudflaps and a good set of tin snips to cut the plastic.
  11. Jun 29, 2009 at 5:48 PM
    thebigk
    thebigk 6 Double 5 3 2 1
    Ken....
    Odessa, TX
    From what I understand with the 5100's & AAL with a 285....DEPENDING ON THE TIRE.....is the amount to trim. A tire with a more agressive tread will need more trimming where as a BFG A/T will need minor trimming.
    I am going with this same setup and anticipating minor trimming.
