Can I flip my leaf springs?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Emmetjmcc4, Mar 31, 2019.
  1. Mar 31, 2019 at 6:09 PM
    #81
    eon_blue
    Azusa, CA
    350k is a lot of miles even for a Toyota. That and the truck being 24 years old would make me (personally) lean toward getting something with less mileage on it if my goal was to have it be a reliable camping/offroad vehicle. Unless I was an experienced mechanically inclined individual and planned on rebuilding/swapping out most of the old OE parts with newer OEM/aftermarket upgrades myself to avoid paying a shop a boatload of money to do it.
    Nothing wrong with taking on a project but projects add up quickly if you aren't doing the work yourself, and offroading takes a heavy toll on a vehicle...especially one with 24 year old parts that have 350k on them.
    If I wanted a cheap daily I'd have no issue driving a high mileage Toyota around town with confidence, but beating one up on the trail is another thing entirely.
  2. Mar 31, 2019 at 6:11 PM
    #82
    Emmetjmcc4
    Emmetjmcc4 [OP] Well-Known Member
    Emmet
    Michigan
    2002 Tacoma 4x4 270k, 1995 Tacoma 4x4 353k RIP
    American Racing 15x8 -19 off. Cooper Discoverer stt pro 31x10.5r15 Allpro baja tube bumper Fox racing 2.0 all around
    im already kicking myself for not doing more research before I dove into this but
    And with next to nothing for knowledge in that field probably not a good idea. thanks for the opinion.
    GQ7227 likes this.
  3. Mar 31, 2019 at 6:14 PM
    #83
    Emmetjmcc4
    Emmet
    Michigan
    and i guess to be honest, i believe I do have the money right now to even swap the engine if I needed to. is that something even practical?
    GQ7227 likes this.
  4. Mar 31, 2019 at 6:15 PM
    #84
    eon_blue
    Azusa, CA
    I started off the same way 3 years ago with my 04 Tacoma...didn't even know how to install a battery myself. After paying shops a lot of money to install new parts I finally starting buying some tools and doing a lot of reading on here and I can confidently do a lot of work on my truck now...all the maintenance, suspension, body work, etc. I'm still learning but I've come a long way in 3 years and you can too.
    I started with a 24k mile truck though so a lot of what I've replaced I've done just to upgrade the truck, but I've also had to make quite a few repairs from a lot of offroad driving...it takes its toll. But it's oh so fun :D
    GQ7227, 303tacoma and tcjacado like this.
  5. Mar 31, 2019 at 6:16 PM
    #85
    eon_blue
    Azusa, CA
    If it runs well, maintains a healthy temperature, isn't burning a crazy amount of oil or losing coolant then I wouldn't worry about that.
  6. Mar 31, 2019 at 6:20 PM
    #86
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I wouldn't worry so much about swapping the motor. The 1st gen motors are very reliable as long as they are somewhat decently maintained.
    I'd look in to timing belt/water pump, valve cover gaskets, suspension components (which you are already doing), radiator etc.
  7. Mar 31, 2019 at 6:20 PM
    #87
    Emmetjmcc4
    Emmet
    Michigan
    She had a small oil leak from the distributor but that was just changed for some warranty work at the shop. she has an intermittent misfire on cylinder 3 though. Which idk how severe that could be.
  8. Mar 31, 2019 at 6:23 PM
    #88
    Emmetjmcc4
    Emmet
    Michigan
    I know the valve cover gasket was changed about a year and a half ago. is changing the radiator something that should be done regularly?
    GQ7227 likes this.
  9. Mar 31, 2019 at 6:24 PM
    #89
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Not regularly but mine blew at about 275,000 miles.
  10. Mar 31, 2019 at 6:26 PM
    #90
    Emmetjmcc4
    Emmet
    Michigan
    Okay, i guess I'm not sure if this is the original or not. there was at one point a pin hole in mine but I haven't noticed it leaking in a while.
  11. Mar 31, 2019 at 6:29 PM
    #91
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I consider rads disposable parts like brake pads. A new radiator and coolant every 100k is good insurence.
    A coolant flush cost $125.
    A new rad is $80, coolant another$20.
    Which way do you think makes the most sense?
    GQ7227, tcjacado and Emmetjmcc4[OP] like this.
  12. Mar 31, 2019 at 6:31 PM
    #92
    Emmetjmcc4
    Emmet
    Michigan
    So overall sensus was keep the truck and fix it? Lol really looking for help here
    GQ7227 and tcjacado like this.
  13. Mar 31, 2019 at 6:32 PM
    #93
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Mine has 290,000 on it. And I'll drive the bitch through Death Valley without hesitation.
  14. Mar 31, 2019 at 6:35 PM
    #94
    koditten
    Kirk
    Central Michigan
    Yes, keep the truck.
    Repairs are much, much cheaper than a car payment.
    Parts are reasonable and easy to find.
    If the truck is maintained, 350k is nothing to worry about.
  15. Mar 31, 2019 at 6:46 PM
    #95
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    That was an auto save from something else, wasn't supposed to be there.
  16. Mar 31, 2019 at 6:46 PM
    #96
    Emmetjmcc4
    Emmet
    Michigan
    Right on, its decided then.
    tcjacado likes this.
  17. Mar 31, 2019 at 6:48 PM
    #97
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It fit in the context of the conversation pretty well tho lol
  18. Mar 31, 2019 at 6:50 PM
    #98
    Emmetjmcc4
    Emmet
    Michigan
    So we've deciphered that i need new suspension all around, I was checking out the all pro suspension kits Would I need to get the expedition leaf springs?
  19. Mar 31, 2019 at 6:52 PM
    #99
    Broke Okie Ty
    Ty
    It did, but I thought it better not to get into it.
  20. Mar 31, 2019 at 6:55 PM
    #100
    Broke Okie Ty
    Ty
    Yes but only if you're never going to unload the rack and tent, if you can afford all of that, then go for it.
