can I get a key made?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomalimited, Feb 2, 2013.
  1. Feb 2, 2013 at 3:16 PM
    tacomalimited
    tacomalimited [OP] Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I just bought a 2013 Tacoma, and the keys have chips in them.I would like to have a key that would just unlock the door in case I ever accidentally lock my key in the truck.I know the computer chip key is expensive and the dealer has to make you one. What I am asking is, can I just take my key anywhere and have a duplicate made? I know it won't start the truck, I just want it to open the door. Thanx!
  2. Feb 2, 2013 at 3:23 PM
    Blueanimal
    Blueanimal Well-Known Member
    New Orleans area, La
    06 Prerunner Sport
    K&N 77 series intake, Throttle boby spacer, Bilstien 5100, Firestone airbags, Brush Gaurd, Gooseneck hitch, Whelen lights and siren
    When I was trying to get one made no one besides Toyota wanted to touch my key. Toyota charged me less than $15
  3. Feb 2, 2013 at 3:45 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes you can get a doors only key made anywhere, Lowes, Home Depot, Walmart, Ace ...
  4. Feb 2, 2013 at 3:46 PM
    tacomalimited
    Northern NJ
    Was it just a regular key? Or did it have the chip? Mine has the theft deterrent imobilizer, from what I read they cost more.I'll check with Toyota on monday, if I can get akey for 15 bucks I'll do it! Thanx!
  5. Feb 2, 2013 at 3:48 PM
    tacomalimited
    Northern NJ
    Ill check lowes and home depot tomorrow, thanx!
  6. Feb 2, 2013 at 3:52 PM
    Blueanimal
    06 Prerunner Sport
    They cut just a regular all metal key. My original is the same as yours with the engine immobilizer.
  7. Feb 2, 2013 at 3:58 PM
    tacomalimited
    Northern NJ
    That's fine. I just would like to keep an extra key with me, in case I accidentally lock my keys in the truck.I have a Lowe's and a home depot close by.Do you recommend one over the other? I'll check both tomorrow.
  8. Feb 2, 2013 at 4:02 PM
    Blueanimal
    06 Prerunner Sport
    Which ever one you prefer. Just check the key to make sure it works before you leave.
  9. Feb 2, 2013 at 4:05 PM
    tacomalimited
    Northern NJ
    Thanx! I'll try tomorrow.
  10. Feb 2, 2013 at 7:10 PM
    BillyP
    BillyP Well-Known Member
    Billy
    Cedar Point, NC
    13 DBL Cab TRD-OR
    I got a non-chip key made at Lowe's for my 2013. I unlocks the door fine, but won't start the truck. Keep it under the truck in a magnetic key holder... anyone finds it, they still can't start the truck.
  11. Feb 3, 2013 at 10:29 AM
    tacomalimited
    Northern NJ
    Got my key made at Lowe's today, 2 bucks! They told me never to use it in my ignition, since it has a chip in it, and the copy don't. He said some cars lock the key in the ignition if you try to use it, and you need to call a locksmith to get it out! :eek: I only wanted it in case I accidentally lock my keys in my truck.I'm definitely going to make sure I never use it in my ignition!!!!!
  12. Feb 3, 2013 at 10:30 AM
    acdronin
    acdronin Well-Known Member
    hmm, i have put the non chip key in and it only refused to start, maybe something with the newer ones
  13. Feb 3, 2013 at 11:24 AM
    seric007
    seric007 Well-Known Member
    you sir, need to check out the link in my sig.
  14. Feb 3, 2013 at 1:44 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I too have a plain key for that reason, and same result in my '06. Cranks over fine, just no fire. It didn't lock out, and started fine with the chip key after. Take advice from lowes, home depot, etc with a grain of salt.
  15. Feb 3, 2013 at 4:48 PM
    BillyP
    Billy
    Cedar Point, NC
    13 DBL Cab TRD-OR
    First thing I did was try my new key in the ignition. Cranked it over fine... but no start. No locking the key in the ignition.
  16. Feb 3, 2013 at 4:54 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    After purchasing my truck the dealership sent a blank plastic credit card key in the mail... had to take it to them to have it cut. It was free and only opens the doors.
  17. Feb 3, 2013 at 6:09 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Ive never heard of this "feature".
    Not saying it isn't true, but I'll have to throw the bullshit flag on this until proven otherwise.
  18. Feb 3, 2013 at 6:34 PM
    tacomalimited
    Northern NJ
    I never heard of it either, sounds like a croc, but, why take a chance? Does anyone know what a programed chip key cost at the stealership?
  19. Feb 3, 2013 at 7:04 PM
    seric007
    i "Tested" my new unprogrammed key several times prior to programming it to the ECU.. it does NOT lock you out.
  20. Feb 3, 2013 at 8:17 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    About $150 -175 here for the key and programming here in Canada, you guys in the US will probably be slightly less.
    Seric's thread shows a way that costs about $40, including the tool.
