Can i get away with it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by magic, May 30, 2012.
  1. May 30, 2012 at 9:17 PM
    magic
    magic [OP] Well-Known Member
    right now i have 285-75-16 tires with 16x8 rims with 4.25" BS. Im looking to upgrade to some beadlock wheels and maybe push my tires out some more as well. I was thinking about 16x8 with 4.00" BS or 16x8 with 3.75" BS. Right now with the 4.25 i dont rub cause i trimmed some black plastic inside the fender well but will i rub on my UCA or on the frame with 3.75" or 4.00" BS?
  2. May 30, 2012 at 9:29 PM
    trmarshall1
    trmarshall1 The Least Interesting Man In The World
    Tim
    San Jose, CA
    02 Tacoma 4x4 TRD Supercharged
    4" Pro-Comp Lift, TRD cat back exhaust, grey wire mod, clutch pedal linear spring mod
    what tire size? My 305-70-R16's rub the shit out of the frame at full lock.
  3. May 30, 2012 at 9:31 PM
    magic
    im keeping the 285-75-16 and they barley rubb at max with the 4.25"BS
  4. May 30, 2012 at 9:31 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    im running 16x8 with 3.625" backspace and 285-75
    4" backspace will sit just right with stock fenders and bedsides...
    less than 4" and you may end up rubbing on pinch weld or even on flares at full turn...
    you could always go as crazy as 3.625" and run glass fenders and you will clear fine...
  5. May 30, 2012 at 9:32 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yep... beadlocks could be more hassle than worth...
    maybe consider a streetlock wheel...
  6. May 30, 2012 at 9:37 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    the less backspaced wheels will make the tire stick out farther making it have more clearance on the uca and frame. right?
  7. May 30, 2012 at 9:38 PM
    magic
    I have the SR5 package so i dont have the black fenders but right now with the 4.25" BS my tires sit outside the fender wall about 2.5"s. And ya idk about beadlocks all i really want is some type of black rim with red because my truck is red. and i would like my tires to sit out a little bit more
  8. May 30, 2012 at 9:39 PM
    magic
    If thats the case them i in good shape but i think the more you push ur tires out(less backspace) means the more you will rub at full turn or drop
  9. May 30, 2012 at 9:45 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Buy some of the cheap 1/4" spacers on ebay and put them on with ur wheels for a test fit I think there like 25 a pair but its cheaper then getting wheels you hate that rub. I am not saying run these non bolt on spacer for a long time I think they are unsafe. As far as wheels you want whats called streetlockor fake beadlocks.
  10. May 30, 2012 at 9:49 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    the more backspace you have, the likely you are to rub the inner corner of the tire on the frame at full turn, and the upper sidewall on the stock UCA...
    the less backspace you have, the likely you are to rub the outer corner of the tire on the pinch weld, or stock running board, or the front lower valance of the bumper at full turn...
    i have run everything from 4.625" to 3.625" backspace and it's a matter of finding the happy medium..
    with the stock parts on the truck, i found that 4" had the least amount of rubbing on either side of the tire...
    what can help is to keep the caster of the front wheels between 1.25 and 1.9 degrees forward, and suspension lift of 1.5" or more...
    at least that formula worked on my first get dcab... the xcab and reg cab sit a lil higher by design, so you won't need as much adjustment as the dcab does...
  11. May 30, 2012 at 9:50 PM
    santabarbarataco
    jordan
    santa barbara
    well im running 3.75" bs with a 1.25" spacer in the front and i dont rub with a 32"x 11.5" procomp mt so i think you should be fine
  12. May 30, 2012 at 9:51 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    without the black flares, 4" or less backspace will give you that "skateboard" look, but you may have to go with 4" to avoid the rubbing...
  13. May 30, 2012 at 9:57 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    wait, you're running at 2.5" backspace then?
    it doesn't look like it in your truck pics...
  14. May 30, 2012 at 10:01 PM
    magic
    well going to 4.00"bs would only add another .25" of tire sticking out of the fender walls so i doubt it would give me the skateboard look. Thats correct that it will only add .25" of tire sticking out if i go from 4.25bs to 4.00bs right?
  15. May 30, 2012 at 10:15 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    true... at that point, another quarter inch wouldn't matter...
  16. May 31, 2012 at 8:27 AM
    santabarbarataco
    jordan
    santa barbara
    yes basically i have 2.5" in the front but i only sticks out of the fender maybe 2" or so :notsure:
  17. May 31, 2012 at 9:35 PM
    magic
    So any suggestions for streetlock rims (black with red)? and take in to account i dont want to spend over 600. thanks
  18. May 31, 2012 at 9:51 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    most wheels are simulocks (fake beadlocks) which are legal to run on the street. unless it says "beadlocks" they are most likely simulocks
    Which wheels were you looking at getting?
  19. May 31, 2012 at 9:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    i had the series 52 streetlocks and the ring and bolts can be removed...
    the guy i sold them to took the rings off and painted them red...
    i think you can get those wheels for $85 to $125 per wheel...
  20. May 31, 2012 at 10:00 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    $125 a wheel at 4WP... you can find them cheaper...
    series 152 pro comp...
