Can I get TSBs on my '05?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by memario1214, Jun 13, 2010.
  1. Jun 13, 2010 at 6:41 PM
    memario1214
    memario1214 [OP] Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    I have a 2005 DCSB TRD Sport and I am wondering, can I get the new TSBs for it? Can I get say the bent tailgate one, or even the new susp one? Also, can someone elaborate on what the suspension one does? Just wondering because my rear leafs are FLAT as a pancake, almost trying to make a St. Louis arch on me... Let me know what you guys know. Thanks!
  2. Jun 13, 2010 at 7:01 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can't get any of them if you are out of warranty.
    The suspension one replaces your 3 leaf pack with a 4 leaf one so you have more payload capacity.
    You can just buy an add-a-leaf for under $100 and fix that problem yourself. Fat Bobs Garage and wheelers have nice, inexpensive options.
  3. Jun 13, 2010 at 7:03 PM
    Brunes
    Brunes abides.
    Rotorhead
    The suspension one does not increase your payload capacity. It provides proper spring response to carry the published capacity weights.
    It is UNlikely you'll get the TSBs done on your 2005 truck...but you can ask...
  4. Jun 13, 2010 at 7:05 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    I figured as much... But I had to ask. Also, will an AAL fix my reverse curve leaf problem, or do I need to get all new leaf packs and then add a leaf to get a lift?
  5. Jun 13, 2010 at 7:07 PM
    Mondwa
    Mondwa Well-Known Member
    Michael
    Phoenix, AZ
    08 V6 Tacoma
    remote start, Allpro bumper, Slimchubby HID, MetalMiller custom Emblem
    i would try to call glacier toyota as they were more than happy to get me done. but try a couple of dealers
  6. Jun 13, 2010 at 7:08 PM
    Brunes
    Brunes abides.
    Rotorhead
    You can do any of those.
    If you are thinking about/can afford new leaf packs- Do that. You can put an AAL in the leaf packs you have already, you can get them rearched...but a whole new pack will be the best bet, specially if you are trying to lift cause you can get lift leaf packs.
  7. Jun 13, 2010 at 7:10 PM
    KPT
    09 Prerunner
    ?? If the truck can't properly carry the published capacity before the TSB, and after the TSB it can, then it does increase the actual payload capacity, right?
  8. Jun 13, 2010 at 7:15 PM
    Brunes
    Brunes abides.
    Rotorhead
    It's semantics- but it does NOT increase capacity- it improves the ability to carry the published weight.
    The truck will carry the weight as published with the 3 leaf springs-not comfortably...but it will.
    Saying "increases the payload capacity" reads dangerously like "you can carry more stuff than published or more than before"
  9. Jun 13, 2010 at 7:23 PM
    KPT
    09 Prerunner
    Pre-tsb, mine carried the published weight with the bump stops, the springs were in no way involved :laugh:
    Fair enough on my improper use of the term though.
  10. Jun 13, 2010 at 7:32 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Mike, I never asked, but were/are you out of warranty?
  11. Jun 13, 2010 at 7:44 PM
    Black Taco
    Black Taco Well-Known Member
    Rob
    WPB, FL
    TOYOTA
    Not OEM.
    I recently tried to get the suspension TSB done on mine. They checked the VIN and told me only the pads between the leafs would have been covered ($57 dollars) for the sqeaks. Basically they told me to go F- myself.
