Can I just use synthetic 5w-20 instead of 0w-20?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Flash1034, Aug 22, 2018.
  1. Aug 25, 2018 at 9:58 AM
    #61
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    he did not care what he payed for that truck but he is saying oil is to expensive he is all f/// up in the head
  2. Oct 29, 2018 at 4:04 PM
    #62
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    10K is too much mileage between changes, from what I can see. While the oil still looked great on the dipstick at 7K, at 10K it was dark black and slightly burnt smelling when I drained it this weekend. I'll be changing between 5K and 7K from now on. Nothing scientific in this opinion, but it definitely will help peace of mind to change the oil more frequently, since I plan to keep this truck and pass it on.
  3. Oct 30, 2018 at 5:56 AM
    #63
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    never had one issue finding 0W-20 full synthetic oil...
  4. Oct 30, 2018 at 7:07 AM
    #64
    Mopar Mussel
    Mopar Mussel Well-Known Member
    Jurgis
    2018 TRD Sport, 2006 SAAB 9-5 Aero
    5w might be a little cheaper, but think about it like this: A blown-up motor costs way more than a gallon and a half of oil.
  5. Oct 30, 2018 at 8:48 AM
    #65
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Been using 5W-30 ever since I got my taco (17,6XX miles) and never a problem. Actually I feel it runs better on 5-30 than 0-20.
    Scott4032 likes this.
  6. Oct 30, 2018 at 9:16 AM
    #66
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    How so?
    hiPSI and shakerhood like this.
  7. Oct 30, 2018 at 9:25 AM
    #67
    Dacon
    Danny
    Gilbert, Arizona.
    It feels a bit quieter and smoother (engine).
  8. Oct 30, 2018 at 9:44 AM
    #68
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    It's simple to quantify 5w-30 vs 0w-20 results
    www.blackstone-labs.com
    Everything is else bullshit, conjecture, and ignorance
    hiPSI, Hank Heel and TacomaMike37 like this.
  9. Oct 30, 2018 at 10:20 AM
    #69
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    If you think using 5w vs 0w will blow up a motor you need to hand your man card in and go buy a prius.
    BillsSR5, Scott4032 and Tacos4ever15 like this.
  10. Oct 30, 2018 at 1:08 PM
    #70
    Mopar Mussel
    Jurgis
    I know it won’t blow up a motor, I was using hyperbole to make a point. Oil, compared to a truck, is not expensive. Why not use the good stuff?
    And I don’t really see what point you’re trying to make about me with that last bit.
  11. Oct 30, 2018 at 1:15 PM
    #71
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    they dont spec thinner oil because the tolerances are tighter. It's for better MPG.
  12. Oct 30, 2018 at 1:35 PM
    #72
    Sep1911
    2016 Taco
    https://www.ebay.com/p/OEM-TOYOTA-0w20-Full-Synthetic-Motor-Oil-Case-of-12-Quarts/655351977
    Just buy online and be done with it. TGMO is one of the best 20 weight oils on the market.
    OP I dont know where exactly in Cali you live and how cold it gets, but unless it gets colder than -22F 5w20 will be fine. Do keep in mind that 0w20 is going to have better cold flow properties, even when not in extreme cold weather and that the base stock on a 0w20 is usually going to be higher quality.
    #72
    WARPED5 likes this.
  13. Oct 30, 2018 at 2:13 PM
    #73
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    Just ignore Toyota truck specifications, the best in the business worldwide. Toyota just wants you to wear it out sooner so you can buy a new one and repeat. Whew!
    Jemm63 likes this.
  14. Oct 30, 2018 at 2:40 PM
    #74
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Yes and the same 3.5L engine specs 5W30 in Europe
  15. Oct 30, 2018 at 3:09 PM
    #75
    Sum1 Else
    Sum1 Else Well-Known Member
    The argument about what viscosity is understandable.
    But here is the deal. Even if you change your own oil, you must prove (receipts) that you use the recommended oil and filter or the fight starts if you have a warranty issue.
    I know why Toyota does this, they want you
    to return to dealship for their service.
    If you wish to change your own oil, get
    ready for lots of proof. Example is receipt
    for oil at Walmart for someone else’s car, that receipt does not prove it actually went towards your truck.
    So the 5w20 or 0w20 don’t mean shit unless
    performed at dealership to cover warranty.
    So if Toyota Care is covered with standard
    25,000 miles service, it is the other 25k
    miles you have to worry about if you do your own oil changes or otherwise 50k under
    Toyota 50k driveline, powertrain warranty.
  16. Oct 30, 2018 at 5:29 PM
    #76
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    No it won't lol. They both have a flat viscosity index. They flow the same through normal operating temp range.
    #76
    shakerhood likes this.
  17. Oct 30, 2018 at 6:00 PM
    #77
    Sep1911
    2016 Taco
    0w20 flows better at cold and hot temps, look up data sheets
    GA59SnsfGMuyW4zj likes this.
  18. Oct 30, 2018 at 6:05 PM
    #78
    Tallgrass05
    Tallgrass05 Well-Known Member
    Why cheap out on the lifeblood of the engine?
  19. Oct 30, 2018 at 6:10 PM
    #79
    RustyTrumbone
    RustyTrumbone Well-Known Member
    Phil McCracken
    2018 Tacoma SR5 Short Bed
    I'm with you 10k is way too much, the oil might be "fine" but those additives have to be wearing out
    gilligoon[QUOTED] likes this.
  20. Oct 30, 2018 at 6:16 PM
    #80
    Taco Mustard
    Taco Mustard Well-Known Member
    TRD SPORT
    I went for my 5000mi yesterday and they wouldn’t change my oil even though I asked. They were 100% certain 10k is good. I know the oils are better then yester year but 10000mi seems way long.
