Can I Keep Stock Speaker Wires w/ New System?
Discussion in 'Audio & Video' started by Shaowei, Jan 17, 2013.
  1. Jan 17, 2013 at 6:56 PM
    Shaowei
    Shaowei [OP] Well-Known Member
    New Mexico
    05 Tacoma 4x4 LB
    Hello Everyone,
    Noob question. I have a 2005 DC with JBL sound. I'm planning on upgrading to a new HU with a 5-channel amp (door speakers & 1 sub) and new door speakers all around. For simplicity sake, I would like to use the existing speaker wire, especially since all the speaker wires converge in the rear where the new sub will be installed. Through other threads I've found which color wire goes to which door. I'm comfortable cutting into the existing wires and splicing them to the new amp.
    Sorry, long opening, so here is the question. I'm wanting to install new component speakers in the front. What are my best options to simply installation? Would I be able to integrate an external crossover into the stock wiring? Would it be best to go for a component system with an integrated crossover? Other options?
    Also, I know keeping and using the stock wiring isn't optimal but I'm looking for time savings right now. Maybe I'll go all new in the future. Thanks for the help!
  2. Jan 17, 2013 at 8:33 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Not sure about the component set, I'll let someone else take that. I used a pair of 6x9's and also retained the stock tweets..my guy pulled new wire b/c I didn't have the JBL, just another way to go.
  3. Jan 17, 2013 at 8:35 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If your installing a 5 channel amp run new speaker wiring
  4. Jan 19, 2013 at 2:34 PM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    Thanks for the input so far. Any other thoughts or insights?
  5. Jan 19, 2013 at 2:52 PM
    SoCalTacos
    SoCalTacos Turd runner
    socal
    2017 4Runner TRD Pro
    Led head/dtr lights.
    To get the power from the amp to the speakers a "better" line of wires would be highly recommended. No sense in spending money on New components and amps if you won't get the most out of them.
  6. Jan 20, 2013 at 12:52 PM
    Shaowei
    New Mexico
    05 Tacoma 4x4 LB
    Thanks NM Taco. I'm in Rio Rancho. More and more it seems like running new wire is the best way to go.
    That being said, let me pose a new question. What's the best way to lay out the wire for a new installation? I know to run the amp power along the driver side back to the amp. How about the HU RCA out to the amp? From amp to door speakers? Anybody find a best method for this?
  7. Jan 20, 2013 at 1:33 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    The sill plates pop out really easy. Make sure your rcas are long enough, i have my amp under the drivers seat so i had to run the rcas on the drivers side and amp power on the passenger side. Getting new wiring thru the rubber boot in the door is kinda tricky, i pulled them thru with a coat hanger.
  8. Jan 24, 2013 at 4:48 PM
    sparks772
    sparks772 Member
    For the boots I used a zip tie which I saw suggested on mr.marvs tutorial, also if your mounting your amp under driver seat get more than 50' of wire Wally World has cheap scoche spools that I used. Evan what size rca's did you use for your amp, my kit came with 16' but I was told specifically not to coil the slack up as it could create signal noise and that I should try to find 9' ones but I can't seem to find 9 ' ones lol. Only thing I "could" do would be to route RCA cables around back seat then to the amp but that's a hassle lol.
  9. Jan 24, 2013 at 4:56 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    My RCAs are 11.5 feet. The length worked out pretty well, i left some slack behind the kick panel but i didn't have to much slack to the point i had to coil them up
  10. Jan 24, 2013 at 4:58 PM
    Aw9d
    Aw9d That one guy
    I use an old car antenna to feed the power wire through the firewall and also used the same antenna to push speaker wire into the doors. I ran all 12g wire and running 2 pairs into the doors (tweeter/woofer) was a bitch. Lithium grease makes it a lot easier.
    If you run and aftermarket deck, run better speaker wire.
  11. Jan 24, 2013 at 5:11 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    :D
