Can I keep stock UCA if I am leveling the truck with fox 2.5 coilovers?
Discussion in 'Suspension' started by taco_newb, Jan 3, 2020.
  1. Jan 3, 2020 at 11:29 AM
    taco_newb
    taco_newb [OP] Well-Known Member
    2018 TRD Offroad 4x4 DCSB Barcelona Red
    I have seen people do lifts with stock UCA. If I am going going to be lifting the front by an inch or two, can I keep stock UCA?
    Edit: I will be running stock tires and rims.
  2. Jan 3, 2020 at 11:32 AM
    su.b.rat
    su.b.rat broken truck
    probably, or maybe. depends on everything added up such as tire size, wheel offset, lift hardware, etc. what hardware are you looking at including wheels/tires?
  3. Jan 3, 2020 at 11:32 AM
    taco_newb
    Thanks for the comment. I will be runnign stock tires and rim for now. Just wanted to upgrade suspension.
  4. Jan 3, 2020 at 11:35 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    Yes. However, you may need an aftermarket UCA to achieve greater alignment caster, if you are also increasing your tire size.
  5. Jan 3, 2020 at 11:36 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Yes, but you will scrub the outter edges of the tires. You will be much happier if you replace the UCA. Good luck with your truck.
  6. Jan 3, 2020 at 11:36 AM
    su.b.rat
    that shouldn't be a problem. sounds like nothing extreme.
    there are other benefits to increasing caster such as driving dynamics and steering feel for those into the driving part if you're into that. i think these trucks drive crappy at low caster, but you wouldn't know unless you changed it.
  7. Jan 3, 2020 at 11:39 AM
    taco_newb
    Thank you. I guess I will just buy new UCA.
  8. Jan 3, 2020 at 11:40 AM
    su.b.rat
    highly recommended. :thumbsup:
    taco_newb[QUOTED][OP] likes this.
