Can I lift in this order?
Discussion in 'Suspension' started by jimmybee1108, May 12, 2012.
  1. May 12, 2012 at 12:02 AM
    jimmybee1108
    jimmybee1108 [OP] Well-Known Member
    JM
    San Antono
    2012 blk DC sr5 v6 prerunner
    bilstein 5100s, wheelers AALs, amazon dual 10 sub box, with two jlw1s cheap HIDs
    Right now I have a completely stock 2012 taco dc lb. Not 4wd
    Getting 285s off my friend with 18s.
    So I seek guidance on how to go about this cheaply but effectively.
    Could i make it happen in this order?
    1. Bilsteins in the front set to 2.5
    2. Put on wheels and tires
    3. Bilsteins in the back set to 2.5
    4. OME 2.5" coils in the front, reset bilsteins to 0
    5. Toytec 2" AALs in the back, reset bilsteins to 0
    6. TC UCAs in the front
    Anything else that I might need to add? Or something I need to do instead.
    The point is to get the wheels on as soon as possible, knowing the 285s won't fit kindly with stock suspension.
  2. May 12, 2012 at 12:09 AM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    you're still going to have to take of the mud flaps
    I'd just order the full OME kit with UCAs and an AAL.
    there is no such thing as cheap and efficient when it comes to suspension.
  3. May 12, 2012 at 6:29 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    No such thing as Bilstein rear lift shocks adjustable in height.
  4. May 12, 2012 at 11:36 AM
    jimmybee1108
    JM
    San Antono
    twistedfreedom: I see u have the OME coils and AALs.
    how much was that and do u recommend it?
  5. May 12, 2012 at 11:41 AM
    jimmybee1108
    JM
    San Antono
    and is it on stock shocks?
