Can I make my tail lights 5 pin?
Discussion in 'Lighting' started by Bigfishhunter, Aug 18, 2014.
  1. Aug 18, 2014 at 7:25 PM
    Bigfishhunter
    Bigfishhunter [OP] Member
    I am wondering how I can make my tail lights a five pin system. Currently I have a four pin on my 2006 SR5 double cab. I bought a boat with a five ion and while an adapter gets me from a to b I don't have breaks without the five.
  2. Aug 18, 2014 at 7:39 PM
    Bigfishhunter
    Check that I meant my trailer lights.
  3. Aug 18, 2014 at 10:02 PM
    kd8bao
    kd8bao Well-Known Member
    Henry
    Cleveland
    2000 Excursion 7.3L - Ex '11 Taco DCSB
    How about going to a 7 pin? Do you have a tow package
  4. Aug 19, 2014 at 7:09 AM
    Bigfishhunter
    The truck did not come with a tow package. However I have had a receiver and a four ion system installed. I don't believe I need a 7 pin system but then again I have done well with a 4 pin for a long time so who knows. I guess if I'm going to upgrade the trailer lights why not go all the way.
    Ok what does it take?
  5. Aug 19, 2014 at 7:38 AM
    BamaToy1997
    Bill
    Navarre, FL
    Well the first question I would be asking you is WHY are you looking at 5 pins?
  6. Aug 19, 2014 at 8:21 AM
    Indy
    Indy Master of all I survey.
    Its easy, just a new plug and some extra wire. I wouldnt bother with a 5 though. 7 is more versatile. I usually end up swapping all my 4 pin trailers to a 7 so i dont have to worry about adapters. But i have a 4/7 plug on the truck now so no worries either way"
  7. Aug 19, 2014 at 8:53 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's both as easy and as hard as pulling out your existing 4 wire trailer pigtail harness and replacing it with a 5 pin harness.
    Since you're asking the question, I'm guessing you didn't install the original harness.
    It's the work of an hour or two if you know what you're doing. If you're painstakingly tracing wiring diagrams and reading the magnifying glass fine print on the trailer harness wiring - best to allow a full Saturday for the job.
  8. Aug 19, 2014 at 8:57 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
