Can I mount a hilux turbo on my tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aspringfield, Jan 6, 2015.
  1. Jan 6, 2015 at 6:37 PM
    Aspringfield
    Aspringfield [OP] New Member
    '12 Tacoma 2.7
    3"lift 33"km2
    I came across a hilux turbo with all the parts to it and was wondering can I mount it or would I need to get a new manifold for it does anyone know about this
  2. Jan 6, 2015 at 6:42 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    All the hilux turbos are diesels..... to my knowledge
  3. Jan 6, 2015 at 6:48 PM
    Aspringfield
    '12 Tacoma 2.7
    3"lift 33"km2
    They are I've worked on them over seas but I did not know if there is a difference in a diesel turbo and gas turbo I've been told both ways but they are both 4cyl trucks
  4. Jan 6, 2015 at 9:52 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    'cause 2016 Tacoma will be a diesel turbo? :notsure:
  5. Jan 7, 2015 at 1:58 PM
    CaptAmerica
    Cap
    In a van down by the river
    Gen 2.9 DCLB TRD Sport w/tech
    Stickers and not enough wax
    Um, Hilux is not Tacoma. It's barely Tacoma-lite. Different market, different frame, different truck.
