Can I move the stock battery to the “secondary “ spot without issues
Discussion in 'Technical Chat' started by mysubiewasalemon, Jun 10, 2021.
  1. Jun 10, 2021 at 8:44 PM
    mysubiewasalemon
    mysubiewasalemon [OP] Well-Known Member
    Am I able to move the stock battery from the front driver side to the passenger rear of the bay without running into issues .
  2. Jul 8, 2021 at 5:10 PM
    mysubiewasalemon
  3. Jul 8, 2021 at 6:04 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends on your wiring Skills .Define Issues ??
    Your going to move cables around not sure if any new ones need made
    Why does it need moved?
    I am guessing no ABS or cruise control.
  4. Jul 8, 2021 at 6:43 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Short answer yes if you can fab up a proper battery tray, use the correct wiring, and route everything where it won't rub, short, or melt you shouldn't have issues with a relocation.
    I wouldn't recommend doing it if your unsure of how to go about that kind of stuff as a screwup could get expensive quickly if something gets shorted or reverse polaritied.
    Naveronski and PhenixFord like this.
  5. Jul 8, 2021 at 6:47 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Agree with @Dm93 . It's just a battery. Doesn't matter where it is as long as its protected and install properly. The battery in my wifes Acadia is under the floor.
  6. Jul 9, 2021 at 1:47 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    OP if your asking you might want help.
