can i paint my radiator?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nepil, Mar 6, 2011.
  1. Mar 6, 2011 at 9:25 AM
    Nepil
    Nepil [OP] BEACH BUGGY
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    I'm about to install my new mesh grill. Because of the size of the holes, you can really see the light grey behind it. If I lightly rattle can it flat back,do I run a risk of messing it up? Thanks in advance.
  2. Mar 6, 2011 at 9:28 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Any coating will reduce the efficiency of the radiator.
  3. Mar 6, 2011 at 9:31 AM
    rcfreak201
    rcfreak201 Well-Known Member
    nah your fine, alot of guys do it but i believe there is a paint specifically for painting them so try looking into that but im not 100% sure
  4. Mar 6, 2011 at 9:34 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Just because people do it, doesn't mean its "okay" to do :laugh:
    :p
    I won't paint mine because I live in AZ and it really, really, really HOT here...I don't wanna take the risk of it :eek:
  5. Mar 6, 2011 at 9:39 AM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX
    2018 F-150 5.0
    RIP to my 08 Prerunner DC
    I did mine in Grill paint. I havn't noticed anything not even 1 degree of temp climb. What I did was go kinda heavy on the side pilars and then just lightly mist the fins. I just wanted to slightly change the color not clog the whole thing up.
  6. Mar 6, 2011 at 9:40 AM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    x2
  7. Mar 6, 2011 at 9:43 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I don't see where a light misting of the radiator will do any harm to the effects of the cooling system.
  8. Mar 6, 2011 at 9:44 AM
    Nepil
    Josh
    Carolina Beach
    99 reg cab 2.7 4x4
    always wrenchin'
    That's exactly what I'll do. Thanks guys.
  9. Mar 10, 2011 at 2:07 AM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Eastwood makes radiator specific paint. HERE on Jegs.
  10. Mar 10, 2011 at 7:20 AM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    Actor, Director, Badass, Paint supplier. that guy does it all
  11. Mar 10, 2011 at 7:32 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Yes, It does not affect the efficiency of the radiator. The eastwood stuff is good as well, I have used it in the past on radiators and intercoolers.
    Most radiators are painted black from the factory anyways. Some people have argued that black painted radiators are actually more efficient than if they weren't painted.
  12. Mar 10, 2011 at 9:08 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    You will be fine. Painting a radiator will not affect your cooling system or its abilities lol...
