Can I please receive a little assistance here.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GoDeacsWFU23, Dec 19, 2011.
  1. Dec 19, 2011 at 2:48 PM
    GoDeacsWFU23
    GoDeacsWFU23 [OP] Well-Known Member
    Jonathan
    Clemmons, NC
    2013 Tacoma PreRunner TRD Sport
    I finally got in one of my factory fog switches with the harness and 4 connectors. Now, how in the heck do I hook it up to my fog lights? I found this picture of what each plug is but it might as well be in German because I have no idea where each one should go. If someone could help me out with this I would be much abliged!
    THIS IS WHAT I HAVE:
  2. Dec 19, 2011 at 4:01 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Anyone? Bueller? Anyone?
    Trying to get this done tonight, not trying to be to pushy.....
  3. Dec 19, 2011 at 4:13 PM
    RCBS
    RCBS "Cause I'm mighty proud of that ragged old flag."
    Appalachia
    06 Main Runner OR
  4. Dec 19, 2011 at 4:17 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
  5. Dec 19, 2011 at 4:20 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    well for starters....your truck did not come with fog lights (from what i see)
    correct??
  6. Dec 19, 2011 at 4:21 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    it has fog lights, this is for a set of after market lights in the grille
  7. Dec 19, 2011 at 4:23 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ah alright...then if your wiring up new lights you need to add the relay and from what ive been told that top diagram should help
  8. Dec 19, 2011 at 4:24 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    It helped, but I would love to have that diagram for a 4 prong switch, Im sorry but when it comes to wiring im an idiot.
  9. Dec 19, 2011 at 4:28 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    the relay is in place, i cut the old switch off and have 3 wires to run somewhere
  10. Dec 19, 2011 at 4:30 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    top two go together-( are associated w/ each other)-- bottom two go together
    Bottom two for switch illumination- top two for fog lights.
    Thats if your labling is correct.
  11. Dec 19, 2011 at 4:33 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    ok from what i remember the top 2 connections (on the stock fog light switch) are the "trigger" or in this case completes the circuit to work...
    the diagram below, i used it to wire up some fog lights on another members truck a while back...might help you a bit :thumbsup: i cant be to sure because i need to be able to see all the stuff in order for me to tell you :(
  12. Dec 19, 2011 at 4:34 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    i will get some pictures up in a sec, hold tight
  13. Dec 19, 2011 at 4:44 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    These are the 3 wires I need to connect to the factory 4 pring switch
  14. Dec 19, 2011 at 4:46 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Westin 55W
  15. Dec 19, 2011 at 4:47 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    Those three wires orignally ran to the switch that came with the lights
  16. Dec 19, 2011 at 5:02 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Ya most of the time it is...cut into the wires and test them with the fog light button...that the best way to do it...those new lights have a fuse right?
  17. Dec 19, 2011 at 5:05 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    yes they do
  18. Dec 19, 2011 at 5:07 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    how do i cut into the lights and test them with the fog light button?
  19. Dec 19, 2011 at 5:07 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Ok, try this first...connect the black wire to the first prong on the switch n the red to the last one...
  20. Dec 19, 2011 at 5:09 PM
    GoDeacsWFU23
    Jonathan
    Clemmons, NC
    even though the last plug is for illumination?
