Can I put 15" rims on a 2009 SR5 4X4
Discussion in 'Wheels & Tires' started by lanthony, Jun 20, 2009.
  1. Jun 20, 2009 at 8:18 PM
    lanthony
    lanthony [OP] Anthony
    Omaha NE
    SR5 4X4
    I have a set of 31X10.5X15 BF Goodrich ATs that are almost new and would like to put them on my new Taco. Will 15" wheels clear everything (brakes) and what offset do I need to get. Thanks in advance.
  2. Jun 20, 2009 at 8:21 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    What size rims are on your truck?
  3. Jun 20, 2009 at 8:23 PM
    lanthony
    Omaha NE
    SR5 4X4
    16" stock steel wheels.
  4. Jun 20, 2009 at 9:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no,im sorry to say that 15 inch wheels will not work on the 2nd gen tacomas.
  5. Jun 21, 2009 at 7:31 PM
    is it windy yet?
    is it windy yet? Well-Known Member
    Kingston On
    '07 TRD Speedway blue
    extang trifecta tonneau, tinted windows, side step bars, sill plates, bug deflector, TRD exhaust, K&N filter, carbon fiber CD surround, tow kit, it's a Canadian truck so the TSB 4 leaf springs and bilstiens were done at the factory, vent visors, ipod adapter, and weather tech mats.
    Are you sure about that? Maybe not all '05+ but some of the 4x2 the 5 bolt ones come with 15" I could have sworn that I was looking at a 2010 4x2 base with 15" wheels at the dealership last week. Now that being said, I don't think that I have seen any 6 bolts with 15" wheels. I'm going to try a set of older toyota 15" six bolts on my '07 later this week, I guy on my way to work is selling them rather cheap, and I want them for my snows. I'll let people know if they fit.
    Ron
  6. Jun 21, 2009 at 7:47 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yes...you are correct, i was speaking about the 6 lug tacomas. the base tacomas(5 lug) come with 15 inch wheels. i misspoke.
  7. Jun 21, 2009 at 7:50 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Yup but what you said still applies to the OP. He has SR5 4x4, thus 16 inch steelies. I heard that the brake calipers prevent you from being able to run 15" wheels
  8. Jun 21, 2009 at 7:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep......the brake calipers being in the way prevent them from fitting on the 6 lug tacomas.
  9. Jun 21, 2009 at 9:13 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    yeah 16" wheels barely clear the front brake calipers so 15s are out of the question
  10. Jun 29, 2009 at 4:51 PM
    is it windy yet?
    Kingston On
    Well I tried to put a older set of Toyota 15" wheels on my 2007. These older wheels have a lot more offset than the stock wheels. They clear the calipers in the vertical axis, they don't rub in the inside of the wheel. However due to the huge offset they wouldn't clear the caliper in the horizontal axis, in other words they rubbed on the side of caliper where the brake pad would sit. Too bad, as the price was right for them, free.
