Can I put 5100 on front with 1.5 inch leveling kit
Discussion in 'Suspension' started by Scottystoy, Mar 6, 2014.
  1. Mar 6, 2014 at 6:46 PM
    Scottystoy
    Scottystoy [OP] Well-Known Member
    Scott
    Pennsylvania
    02 trd prerunner 3.4 v6
    Hellbent 2.5 leveling kit
    Need some help guys and gals
  2. Mar 6, 2014 at 6:48 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    you mean stack a spacer on the 5100?
    Don't do it.
  3. Mar 6, 2014 at 6:50 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Is the 5100 gonna be left on stock height?
  4. Mar 6, 2014 at 7:05 PM
    Scottystoy
    Scott
    Pennsylvania
    The truck is level now.thats the help I need.should I leave it at stock height.and what would that be 0? And the backs would just be the 5125 correct
  5. Mar 7, 2014 at 6:40 PM
    Mainmoe02
    Moe
    Austin, Texas
    Oh, so you already have a leveling spacer on your stock setup and your wondering if you can put 5100's? If that's the question the. Yes you can put 5100's on. And you should leave the C clip on the lowest setting which is "0" or "stock ride height".
    The other option you have with 5100's is removing the spacer lift and adjusting the C clip on the 5100's to the middle setting which is 1.75" lift. I've heard it rides better than a spacer.
  6. Mar 8, 2014 at 5:21 AM
    Scottystoy
    Scott
    Pennsylvania
    That's what I needed to hear thanks guys
