Can I put ACDelco Dexron-VI ATF in my 2007 5 speed automatic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Workhorse_Taco, Aug 9, 2022.
  1. Aug 9, 2022 at 8:07 PM
    Workhorse_Taco
    Workhorse_Taco [OP] New Member
    Keewatin
    2007 White Tacoma TRD
    I recently noticed I had a leak in my top line leading into the ATF filter, and since it has leaked quite a bit. Can I put Dexron-VI in to drive around a bit until i get it flushed and refilled with the proper WS?
  2. Aug 9, 2022 at 8:14 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    Read the back of the bottle to see if that fluid is compatible with WS ATF. If you can't verify then just use Valvoline maxlife ATF and call it a day. I've see posts of people running maxlife instead of WS with good results. If you really want to use WS fluid then go to the stealership and buy some there or from Amazon.
    2015WhiteOR likes this.
