Can I put coilover and keep stock rear suspension?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Oleshka13, Jan 23, 2023.
  1. Jan 23, 2023 at 6:33 PM
    Oleshka13
    Oleshka13 [OP] New Member
    Oleg
    2023 Tacoma TRD Off road
    N/A
    Hey everyone, new member and taco owner here.
    I want to get a 3” lift on my Tacoma and am planning on getting some coilover a with remote resi,
    my question is if I put a aftermarket coilover with a 3” lift, can I keep the stock rear and put a block? Or is it recommended to replace the rear shocks as well?
    thanks
  2. Jan 23, 2023 at 6:38 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    What's the point of a nice resi shock in front if you're going to have a cheapo block in the back?
  3. Jan 23, 2023 at 6:38 PM
    Oleshka13
    Oleg
    N/A
    I heard that rear blocks aren’t bad if you aren’t hauling extra weight or anything
  4. Jan 23, 2023 at 6:39 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Shocks on the rear do nothing for your ride height.
    The "best" way to do it is new leaf springs - whether that is an Add-a-leaf (AAL) pack, like the Icon 3-leaf AAL or a full new one from Deaver, Alcan, Dobinsons, Old Man Emu, et al.
    But a block is ok. 3" may be pushing it. The issue with block lifts in the rear is that you'll probably encounter axle wrap and thunking/thudding from the rear end.
  5. Jan 23, 2023 at 6:40 PM
    Bishop84
    Bishop84 Well-Known Member
    The rear has a lot more motion and usually where to start with resi's (6112/5160)
    1" Blocks are fine on entry lifts, but what are your end goals?
    I associate resi's with moderate to hard offroading, or washboard/service roads.
    Junkhead likes this.
  6. Jan 23, 2023 at 6:41 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    45% of the weight is on the rear when empty. You’ll want rear shocks to compliment the front.
    The purpose of adjustable coilovers with adjusters is to tune the trucks dampening and adjust ride height for optimal performance. A rear block does nothing but add height. Why would you want a stock shock that can’t keep up with the front?
    If you are just wanting height then throw on some cheap bilsteins in the front to go with your block.
  7. Jan 23, 2023 at 6:45 PM
    Oleshka13
    Oleg
    N/A
    It’ll be mostly pavement, but I do want a good ride and be able to take on some hefty bumps off road,
    my eyes were on the RC vertex because they give an actual 3” lift in the front, is there other coilovers that are able to hit that 3” lift in the front ??
  8. Jan 23, 2023 at 6:51 PM
    JoeCOVA
    Joe
    Colorado Springs
    All adjustable coilovers can hit 3” or even more but you aren’t going to get a good ride out of it. You lose down travel, maximum ideal ride height is usually around 2”. RC is probably one of the shittiest shock companies out there. I recommend doing some research here in the suspension threads and using the search function to understand how the Tacomas suspension works and then determine what you should really buy for it.
  9. Jan 23, 2023 at 6:54 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    This guy shoulda bought a jeep
    whatstcp likes this.
  10. Jan 23, 2023 at 6:58 PM
    Oleshka13
    Oleg
    N/A
    Yeah I heard they’re terrible but I read a thread on the vertex and there were a lot of positive reviews of it.
    might just do bilsteins then, would you recommend 5100s or the 6112/5160 combo ?
  11. Jan 23, 2023 at 6:58 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    3rd gens have a lot of rake. Put the front on and see how it looks. Then decide how much you want to lift the rear.
  12. Jan 23, 2023 at 7:00 PM
    JoeCOVA
    Joe
    Colorado Springs
    Probably by a bunch of jamokes.
    We have a large bilstein crowd who can chime in on 5100s or 6112.
    If you have a budget in mind, most of us can piece a few options together for you.
    na8rboy and Junkhead like this.
  13. Jan 23, 2023 at 7:00 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    If you plan 3" in front as other said you should due more than just blocks in back. Plus you better plan on new UCA for the front. As Joe COVA mentioned RC is is bottom of barrel. I wouldn't install them, even if I got them for free.
    JoeCOVA likes this.
  14. Jan 23, 2023 at 7:00 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I wouldn’t do more than 2”
    On Toyota IFS. OME has a pretty affordable 2” lift kits. I’m running OME medium springs/shocks and dobinsons medium rear leafs (Dakars tend to squeak)
    Good ride on and off-road.
    Chew, na8rboy and JoeCOVA like this.
