Can I put King coil overs with stock upper control arm??
Discussion in 'Suspension' started by TXprotrd, Aug 4, 2012.
  1. Aug 4, 2012 at 4:52 PM
    TXprotrd
    TXprotrd [OP] MarioAB
    Mario
    RGV TEXAS
    2011 T|X Pro TRD SuperWhite 4x4
    TRD exaust, Pro Comp lift, GY duratrac 265/75/16
    Can I install some King coil overs with the stock upper control arm..??
  2. Aug 4, 2012 at 4:54 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Sure can. They're adjustable so you can run them at stock height if you really want to.
  3. Aug 4, 2012 at 5:03 PM
    TXprotrd
    Mario
    RGV TEXAS
    you think i can probably get a 3" inch lift..??
  4. Aug 4, 2012 at 5:11 PM
    Pugga
    Massachusetts
    You can but you most likely won't be able to get your alignment within spec with stock UCA's. Anything over 2 - 2.5" and you should be considering new UCA's.
