Can I put Wildpeaks AT3W P265 70R17 on my 23 SR 2WD without a lift or rubbing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mpritc1019, Dec 20, 2022.
  1. Dec 20, 2022 at 8:14 AM
    mpritc1019
    mpritc1019 [OP] Member
    Can I put Wildpeaks AT3W P265 70R17 on a TRD rim on my 23 SR 2WD without a lift or rubbing? The truck came with P245/75SR16. Thanks for the help I am totally new with this stuff.
  2. Dec 20, 2022 at 8:21 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    possibly, if you get an alignment and have the front wheels moved forward, with as much caster as the adjustments will allow. your results may vary. Ski
  3. Dec 20, 2022 at 8:32 AM
    mpritc1019
    The tire shop selling these said they could install them with no lift and no rubbing. Moving the front wheels forward scares me a bit. Going to a 17 inch TRD rim what is the best tire size I should tell him to do?
  4. Dec 20, 2022 at 8:34 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Yes, without any other changes, those are only 31.7" tall, but that's on stock wheels , not aftermarket low offset wheels
  5. Dec 20, 2022 at 8:39 AM
    Clearwater Bill
    Billy
    Largo Florida
    That's called Caster in alignment settings. SOP.
    Compare your sizes with the Tire Calculator.
  6. Dec 20, 2022 at 8:40 AM
    mpritc1019
    I think I asked the question wrong. The truck came with 16 inch wheels. The shop has 17 inch TRD rims with Falken tires that he will install. I just dont want to do a lift or move wheels forward. Just want plug and play. What size 17 inch falken should I ask for? Again I am a total newb.
  7. Dec 20, 2022 at 8:42 AM
    Clearwater Bill
    Billy
    Largo Florida
    Re read post 5 and the link in it.
    MSN88longbed likes this.
  8. Dec 20, 2022 at 8:44 AM
    mpritc1019
    Thanks! Post 5 came in as I was typing post 6.
  9. Dec 20, 2022 at 11:43 AM
    skidooboy
    central lower mich
    I Have 17" sema wheels, & 265-70r17 tires on my sport. when it was stock, it rubbed on a flaps slightly, when turning while going up or down an incline, in limited situations. lifted the truck 2" front, and 1" in the rear, had an alignment and asked for as much caster as possible to avoid the rub... common practice to avoid rubbing, no draw backs. by doing this, you extend the wheel base slightly, and I mean very slightly. this actually aids in steering comfort and control, making the truck more stable at highway speeds. no need to be afraid. Ski
  10. Dec 20, 2022 at 12:01 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Yes. I did. No problems no rubbing.
    Junkhead likes this.
  11. Dec 20, 2022 at 3:04 PM
    mpritc1019
    The shop has 16 and 17 inch TRD rim and wheels. Should I just stay with the 16 inch since that is the size it is supposed to be?
  12. Dec 20, 2022 at 5:13 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    16" rim is fine, but if you wanted to go bigger next time, like a skinny 33", then your better off with a 17" rim. More tire choices in the 17".
  13. Dec 20, 2022 at 8:29 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
