Can I repair my ARE CX camper myself
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aggiesdm, Apr 24, 2012.
  1. Apr 24, 2012 at 8:47 AM
    Aggiesdm
    Aggiesdm [OP] Well-Known Member
    San Antonio
    17 TRD OR 4X4
    SnugTop topper, WeatherTec mats, thats all for now
    Hi, I have an ARE CX camper top and the plastic "flashing" piece at the bottom of the rear door has cracked and is sticking out. I called the ARE dealer and they want $50 for the piece. Although thats not terrible, I was wondering if anyone had ideas of how to do it myself? Its the piece that covers the junction between the tailgate and the door and its made out of some sort of brittle, molded black plastic. Where could I get such a piece? I'd have to drill out the rivets and re-rivet it myself, but thats no big deal. Any advice is appreciated.
  2. Apr 24, 2012 at 11:07 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    If all you gotta do is drill out the rivets, then seems straight forward. use a drill stop though set on 1/4" or something shallow. Start small with the bit and work your way up till you find the right size, no need to drill the actual material.
  3. Apr 24, 2012 at 11:11 AM
    scocar
    scocar Patron of the Farts
    Look online for one of these places near you.
    http://www.interstateplastics.com/
    They carry all kinds of stuff and can probably provide something similar (even better).
  4. Apr 24, 2012 at 11:24 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would buy the piece from a dealer or online and install it yourself. I wouldn't suggest fabbing something to work.
  5. Apr 24, 2012 at 12:41 PM
    Hard
    Hard Well-Known Member
    H
    4X4X4
    ^^^I agree. For $50 its probably not worth your time. The results will be much better with the factory part.
    Im all for projects and being cheap but I think that you would end up getting the factory part in the end.
