Can I Replace Lifter Bucket With Timing Chains On?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeastyDirtSlut, Sep 25, 2024.
  1. Sep 25, 2024 at 9:03 PM
    BeastyDirtSlut
    BeastyDirtSlut [OP] Well-Known Member
    2003 Toyota Tacoma 4x4 TRD SR5 3.4 Auto
    2nd Gen Supercharger, URD 7th injector, 6" Fabtech lift, King coilovers, Alcan lift springs 800# over
    I rebuilt a 1grfe about a year ago and today it started misfiring on cylinder 3. Checked it out and I have 60psi of compression dry and wet, leak down test was pissing air out the intake. So I pulled the valve cover and sure enough the #3 valve bucket clearance is like .002". (kinda guessing because the bucket turns under the cam but my .004" feeler wont fit under it and thats the smallest one I have) So I know I need to replace the bucket with a smaller size thickness but I am wondering if anyone has tried to remove the cam caps with the timing all in tact. This may be a dumb question but if its possible it would save me a ton of work. Anyone seen or done this?
  2. Sep 25, 2024 at 9:12 PM
    BeastyDirtSlut
    I saw that too but I believe that will only work for the engines that have the shim on top of the bucket, I am fairly certain that the 1grfe has the shim under the bucket. If it is under the bucket I need replace the bucket itself with the correct size.
  3. Sep 25, 2024 at 9:21 PM
    BeastyDirtSlut
  4. Sep 25, 2024 at 9:26 PM
    Bishop84
    Bishop84 Well-Known Member
    The issue is why is the clearance so low, I'd be suspecting a burnt valve at that point, a bucket may not be the answer.
    I'd suggest a borescope to check the valve visibly before you tackle the bucket.
    But ya you can remove the tensioner and remove the cams with the timing cover still intact.
    BeastyDirtSlut[OP] and Dm93 like this.
  5. Sep 26, 2024 at 9:56 AM
    BeastyDirtSlut
    I agree with inspecting further, I had planned on doing a leak down with the cam off to make sure the clearance was my leaking issue. I dont have a scope that I can redirect to the valve faces so Ill have to rely on the cylinder holding pressure with the cam off to tell me if the valve is sealing.
    I called the machine shop and they told me that they put in the same buckets when they did the valve stem seals. It ran perfect for about 9 months and 10k miles and just started misfiring on cold starts recently. Engine had 220k miles on it before the rebuild so I am guessing that it was just time for a clearance adjustment and it didnt get caught at the rebuild because it was in spec at the time.
  6. Sep 26, 2024 at 7:13 PM
    FJC MAN
    FJC MAN Active Member
    Bill
    2007 FJ Cruiser
    Are you at .002 for measurement or zero clearance, or actually preloaded? Yes, the follower is the shim.
    BeastyDirtSlut[OP] likes this.
  7. Sep 27, 2024 at 9:45 AM
    BeastyDirtSlut
    I cant tell for sure clearance, the smallest gauge i have is a .004 and it does not fit. The bucket spins easy enough under the cam but I believe the valve is being held open slightly and that is what is causing my loss of compression. My theory was to pull the cam and do the math for a new shim assuming that I was at .002, selecting a bucket that would put me either in the middle of the spec range or maybe even a thou towards the loose side. That way if I am in fact at .000 right now or even a thousandth loaded the valve would still seat. Bad idea? Maybe I'll look around for a smaller feeler gauge.
  8. Sep 27, 2024 at 9:47 AM
    BeastyDirtSlut
    I will also do a leak down with the cam removed to confirm that the valve is seating completely.
  9. Sep 27, 2024 at 3:46 PM
    BeastyDirtSlut
    Im gonna keep posting here in case anyone else is looking for answers since I couldnt find any anywhere.
    Today I was able to get the buckets (lifters) out without taking the timing cover off. I removed the main timing chain tensioner, then removed the exhaust cam gear and loosened the intake vvt gear bolt enough to pull the phaser away from the camshafts locating dowel. I zip tied the exhaust cam gear to the chain so I wont lose the link it was on, also painted the links at the timing marks. I cant remove the intake cam bolt all the way with the timing cover on but it loosens enough to allow to rotate the camshaft freely of the cam gear. I also removed the secondary tensioner on the small chain to give me some room to move things. With that off I loosened the bolts for the cam caps in sequence and once they are removed the camshaft can be moved enough to get the lifters or buckets out.
    On a different note I now came across a different issue. Alldata has an equation as well as a graph chart to help determine the size of the new lifter needed. I have 2 different size cups that were installed one a #39 (.2124") and the other #41 (.2130"), the numbers are stamped where the bucket shim is, on the inside of the bucket. The gaps are a guess for me at this point since I didnt find a feeler smaller than .004". Guessing as close as possible #39 had a gap of .001" (tighter of the two) and #41 had a gap of .002".
    For the intake valves the calculation is x=y+(z-.008) where x is the new shim needed, y is the shim that was removed and z is the gap with the old shim.
    So my calculation for #39 was as follows,
    x=.2124+(.001-.008)
    x=.2124+(-.007)
    x=.2054
    The equation shows I need lifter #20 with a thickness of .2047. (The next size up is #22 with a thickness of .2055 so I figure go with the looser/thinner #20.)
    my calculation for #41 is
    x=.2130+(.002-.008)
    x=.2130+(-.006)
    x=.207
    The equation shows I need lifter #24 with a thickness of .2063. (The next size #26 has a thickness of .2071, once again I decided to err on the lose side with #24)
    Then after all that they have a chart that also shows what bearing I would need based on gap and old lifter size, according to this chart I would need two #26 lifters. I dont have an answer to this yet but I went ahead and ordered #20, 24 and two #26 lifters, they will be here tomorrow. Ill install them and check gap to see if I am in spec. If anyone knows why I am getting different answers using the chart versus the calculation please let me know.
  10. Sep 27, 2024 at 9:44 PM
    FJC MAN
    Bill
    2007 FJ Cruiser
