Can I run 285/75r16 w/FJ Wheels, 5100's @ 1.75 & Mud Flaps?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ostrichsak, Aug 11, 2013.
  1. Aug 11, 2013 at 8:31 PM
    Ostrichsak
    Ostrichsak [OP] Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I did a fair bit of searching and reading and can't seem to find the answer to my specific question so I'll just start a thread hoping to get an answer to my question since I need to get tires in the morning. I currently have stock OR 16" wheels but have a set of the FJ 6-spoke wheels on the way. As I understand it the backspace is 4.5" v 5.5" so the FJ wheels push outwards 1" versus the stock OR wheels. My suspension is currently 5100's front set to 1.75" and the rear is just a TSB. I'm considering AAL in rear and then either springs up front or going to the 2.5" setting but I'm curious if this setup as is will allow me to run 285/65r16's w/o losing the mudflaps. I know some will say to lose them but I like them and they are quite functional for me where I drive. The other option is to just get 265/75r16's and be done with it but I'm afraid that should I go higher with the lift later the tires will look too small. If the 285's will fit the current setup then I may just get them now and then I won't have any worries other than slightly lower MPGs versus the smaller size tire.
    Thanks for the input.
  2. Aug 11, 2013 at 8:34 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I had my 5100s at the highest setting and would still scrub on the fender flares after I took off my mudflaps so probably not
  3. Aug 11, 2013 at 8:47 PM
    Ostrichsak
    Jer
    What wheels? I think I would have to do even more trimming with the FJ wheels but the UCA's wouldn't be an issue. Might just be going with the 265's anyway.
  4. Aug 11, 2013 at 8:49 PM
    Large
    Large Red
    You said 285/75 in the title & 285/65 in the first post. In any case the answer is no.
  5. Aug 11, 2013 at 8:50 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    I have 285's on stock OR wheels with 1.25" spacers billies set to 2.5" and no rubbing after minor trimming. you will not be able to retain the front flaps without rubbing, i already tried.
  6. Aug 11, 2013 at 8:51 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Not exactly what you are looking for, but I run 285/75/16 KM2's on FJ wheels (4.5" BS) with billies @ 2.5" with no rubbing, good alignment & stock UCA's.
  7. Aug 11, 2013 at 8:52 PM
    Ostrichsak
    Jer
    That's the info I was looking for. Looks like 265's it is. Thanks!
  8. Aug 11, 2013 at 8:53 PM
    Ostrichsak
    Jer
    I assume no mud flaps though?
  9. Aug 11, 2013 at 8:54 PM
    650H1
    Michael
    VA
    x2, but i still want some more camber...
  10. Aug 11, 2013 at 8:56 PM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    I'm running 265/75/16 and I removed my front flaps because they would scrub/snag when wheeling and flexing
  11. Aug 11, 2013 at 8:56 PM
    Boone
    Boone, NC
    Airbags deployed
    I removed the small flaps in front of the front wheel well. All others are intact and completely stock. I don't wheel this truck. It sees mild off pavement duty only.
  12. Aug 11, 2013 at 9:01 PM
    Ostrichsak
    Jer
    That's interesting actually and I was thinking about asking after that last post. If I will have to remove the mud flaps even with the 265's then I might as well pop for the 285's but I'd really rather keep them. sounds like I might not be able to.
    I wasn't asking about the inner wheel well liners but the actual mud flaps that hang down behind the wheel wells.
  13. Aug 11, 2013 at 9:01 PM
    650H1
    Michael
    VA
    its a badass set up though!!!
  14. Aug 11, 2013 at 9:04 PM
    Ostrichsak
    Jer
    Yeah, I had a feeling that's what he was talking about. Just getting clarification.
  15. Aug 11, 2013 at 9:05 PM
    Boone
    Boone, NC
    Airbags deployed
    You are aware Toyota specs 113% more travel on the LB right......
    Oh damn nevermind that is only accounting for LB frame flex. Not the percieved 113% Weiner enlargement for having the inadequate SB.
  16. Aug 11, 2013 at 9:10 PM
    Boone
    Boone, NC
    Airbags deployed
    Meh, best I had on short notice.
  17. Aug 11, 2013 at 9:12 PM
    650H1
    Michael
    VA
    when were talking 5.5', an extra 6" doesnt do shit for storage, and keeps you without a locker
    :brianr:
  18. Aug 11, 2013 at 9:15 PM
    06indigoink
    06indigoink Well-Known Member
    Charlotte NC
    06 4x4
    be prepared to loose the front flaps.. thats nothing though. then when your 285's wear out step up to 315's and grab a saw:eek:
  19. Aug 11, 2013 at 9:16 PM
    Boone
    Boone, NC
    Airbags deployed
    With a D70 HD an 8.0 Yota locker is worthless.
    Edit: Well, it is a nice paperweight.
  20. Aug 11, 2013 at 9:18 PM
    650H1
    Michael
    VA
    :( us poor public service folk dont know what having toys like that is like...
