Can I run LT285/75R16 before/wo lift? (daily driver)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Spencer97TJ, Sep 6, 2022.
  1. Sep 6, 2022 at 7:54 AM
    Spencer97TJ
    Spencer97TJ [OP] Well-Known Member
    Spence
    CT
    stock
  2. Sep 6, 2022 at 7:55 AM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Depends how much you’re willing to trim
    Spencer97TJ[OP] likes this.
  3. Sep 6, 2022 at 7:58 AM
    Spencer97TJ
    Spence
    CT
    stock
    Ok, so fenders etc would need modification? Maybe I'll just add the shocks set to 2 inches up front. The truck is nearing 200k on the original suspension.
  4. Sep 6, 2022 at 8:11 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Anytime that you run 285s you’ll have to cut the fender along the cab mounts even with a lift 265 is the biggest way you can go without altering
    jackn7, wi_taco and Spencer97TJ[OP] like this.
  5. Sep 6, 2022 at 8:14 AM
    Spencer97TJ
    Spence
    CT
    stock
    I'll find the thread on that, and cut it! Thanks!
    Motofox likes this.
  6. Sep 6, 2022 at 8:25 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  7. Sep 6, 2022 at 8:43 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    and mind any and all speed bumps and potholes...why STUFF a tire into your wheelwell like that??
  8. Sep 6, 2022 at 9:17 AM
    Spencer97TJ
    Spence
    CT
    stock
    I kinda need new tires now. but didn’t feel like dealing with the lift just yet.
    I don’t wanna get stuck with 265s for another chunk of time.
    I know better do it right or don’t do it.
  9. Sep 6, 2022 at 9:21 AM
    MSgt O
    2013 Tacoma
    understand, but do you have the wheels to fit 285s? You can run 285s but just be careful not to stuff them to hard on stuff and they WILL rub turning..
  10. Sep 6, 2022 at 10:18 AM
    Spencer97TJ
    Spence
    CT
    stock
  11. Sep 6, 2022 at 10:19 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You have a high chance of the 285s rubbing your UCA
  12. Sep 6, 2022 at 10:39 AM
    Spencer97TJ
    Spence
    CT
    stock
    Could 1.25 wheel spacers do the trick there to avoid UCA rubbing?
    Sorry I came from the jeep TJ modding world. I don’t own of those anymore
  13. Sep 6, 2022 at 10:57 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Yeah that would clear it
  14. Sep 6, 2022 at 11:34 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Spacers, how much you want to cut and modify.
    If you plan on leaving the pavement, good luck and god bless you! Post pics!
  15. Sep 6, 2022 at 12:20 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    You can certainly make a 285 fit without a lift...you just need to do the same things that you'd do to make it fit with a lift.
    You'll want zero offset on the wheels to get them away from the UCA. As for the lift, if they don't fit without the lift they aren't going to fit with it since a suspension lift doesn't change the size of the wheel well or the path the tire travels when the suspension cycles.
    SoonToBeOn39s and Alexely999 like this.
  16. Sep 6, 2022 at 12:29 PM
    092trfe4x45sp
    092trfe4x45sp Active Member
    Running spacers to get away from the uca will make contact with the bumper and cab worse. Your increasing the radius of the tires path anytime you increase negative offset (spacers or - offset wheels). If you don’t mind rubbing a little and don’t articulate your suspension very much it will probably work with 0 offset and no spacers.
  17. Sep 6, 2022 at 12:48 PM
    Lambo9418
    Lambo9418 Well-Known Member
    JP
    Black 2019 TRD Pro
    By 265, I assume you are referring to stock-size 265/70R16s? Perhaps consider switching to 265/75R16? I just did so on my truck this past weekend - and lovin' it.
  18. Sep 6, 2022 at 12:51 PM
    Spencer97TJ
    Spence
    CT
    stock
    Thanks for all the info. I want this thing modded right if I do it.
    I bet new 265s Would still look cool with the bil 5100s if I got tires first.
    im torn, because I want to build and overland Classic defender 110 in a few years. Imported 90s model with 300tdi But I want my old reliable taco to be refreshed a bit.
  19. Sep 6, 2022 at 12:52 PM
    Spencer97TJ
    Spence
    CT
    stock
    Edit. They are 70s! This solution will work. Proper Lift eventually.
    I think my general grabbers might be 75.
    But they are so worn now. And unevenly worn. So I was thinking new shocks and an alignment would go along way before new tires
  20. Sep 8, 2022 at 3:15 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    LT285's for a daily driver..... why, you must not like your $$.
    SL / P Rated 265/75's that are light would be your best choice and look good even with a 2in lift.
