Can I run these wheels with no rub?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by j_inciong, Jun 16, 2017.
  1. Jun 16, 2017 at 9:46 PM
    j_inciong
    j_inciong [OP] Well-Known Member
    Jasyn
    Hawai'i
    2016 Black Tacoma TRD Sport
    Looking to pick up these wheels (http://www.varrstoen.com/product/vtx-viper/), either the 17's or 18's. However, they are 17x8.5 and 18x9. Would it be possible to run either of these with KO2s on a stock 2016 Double Cab Sport?
    Thanks in advance!
  2. Jun 16, 2017 at 9:49 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    With what size tires? See the links in my sig below
    j_inciong[OP], RyanL and Silverspool like this.
  3. Jun 16, 2017 at 9:52 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    I only checked the specs of the 17s, with a -10 offset. That's plenty to clear the UCAs up to a 11.5. inch tire easily, possibly a 12.50.
    What size tires are you wanting doing to run? Thats equally, if not more important on if the setup will fit.
  4. Aug 12, 2017 at 8:39 PM
    j_inciong
    Jasyn
    Hawai'i
    I'm not too knowledgeable when it comes to tires but I'm thinking the 265/70/17 BFG KO2s
  5. Aug 12, 2017 at 8:44 PM
    Silverspool
    Frank
    DFW
    18T4RORP 17GT350
    Youll be fine. If 265s i recommend going with the 17x8.5 instead of 18x9
    doorsidedown and j_inciong[OP] like this.
  6. Aug 12, 2017 at 8:47 PM
    j_inciong
    Jasyn
    Hawai'i
    Right on, thanks so much! I'd like to get a lift but not anytime soon, that's a lot of money. So if I could get these new tires and wheels without a lift, that works out nicely.
    Thanks again!
  7. Aug 13, 2017 at 1:11 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    11 79 23 16
    Edit, 49er
  8. Aug 13, 2017 at 4:38 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    -12mm offset is too much; those will poke 1-3/4".
    With 8.5" wide you want something around +12mm offset.
  9. Aug 13, 2017 at 9:19 PM
    j_inciong
    Jasyn
    Hawai'i
    So the specs for the wheels are 17"x8.5", -10mm offset, 4.4" backspacing according to the website. I'm not too knowledgeable on this, but just wanted to clarify if I'd be able to run those with a 265/70/17 BFG KO2 setup and no rub without a lift.
    I'm looking to order the wheels and tires this week.
  10. Aug 14, 2017 at 2:00 AM
    Toyo_newb
    Toyo_newb Well-Known Member
    Matthew
    2017 DCLB TRD OR 4x4 QUICKSAND
    My Icon's are 17x8.5, but they're also 0 offset. So I'm no help. But I can tell you 265/70r17 KO2's are a great tire on our trucks. No regrets thus far.
    j_inciong[OP] likes this.
  11. Aug 14, 2017 at 2:56 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    The 17x8.5 -10mm wheel size is the same as the SCS wheels that are designed to fit our trucks. A -10mm offset will give it a nice stance that's better than stock. I would go with 17's vs 18's to give it a better ride with more sidewall. $.02
    j_inciong[QUOTED][OP] likes this.
  12. Aug 14, 2017 at 6:39 AM
    NIU_Huskies
    NIU_Huskies Well-Known Member
    2017 Toyota Tacoma TRD Sport DCLB
    I have 18x9 Methods with -12 offset. Once installed my tires barely rubbed on the stock mudflaps. I cut out some of the mudflap and the rubbing is about 95% gone. Once I put on the lift the rubbing should be completely gone.
    j_inciong[OP] and Silverspool like this.
  13. Aug 14, 2017 at 12:31 PM
    j_inciong
    Jasyn
    Hawai'i
    Thanks everyone for your replies/advice. So it sounds like rubbing shouldn't be a problem then. I'll start building up the balls to place the order for the wheels and tires this week
    Thanks for helping this newbie out!
  14. Aug 14, 2017 at 12:48 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    Overall diameter: 1.1" greater
    Overall width: same
    You will stick out 1.6" more than stock.
    diameter and width won't be too bad it's the fact that it will be sticking out quite a bit more. I would flex your suspension and lock your wheels either way and take a ruler to make sure you will have the proper clearance. My guess is you will have to do a bit a trimming.
    source:
    265/65r17 x 7.5 et30 VS. 265/70r17 x 8.5 et-10
    https://www.rimsntires.com/specspro.jsp
  15. Sep 18, 2017 at 11:35 AM
    j_inciong
    Jasyn
    Hawai'i
    Thanks everyone for the help, just put these puppies on this weekend. Very minimal rub but nothing a little trimming won't fix.
    splitbolt likes this.
  16. Nov 26, 2018 at 8:38 AM
    THEOUTDOORMATE
    THEOUTDOORMATE New Member
    Tacoma Quick Sand 2018
    Looks beautiful! i have the same truck as yours... did you used 265/70R17??
