Can I safely charge 12v 7ah batt with my truck?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco47, Nov 22, 2015.
  1. Nov 22, 2015 at 8:37 PM
    Taco47
    Taco47 [OP] Well-Known Member
    Norcal
    2016 2TR 5-Speed
    First off this battery is not intended to be used as a dual battery setup. I have a small 12v 7ah battery that I need charged to use tomorrow morning. I want to hook it up to my truck with jumper cables and use the alternator to charge it. I usually use my smart charger at home but I'm out of town. My smart charger has a specific setting for a small battery and for agm gel types which this one is. My truck has a oreileys lead acid type battery. Will this charge safely?
  2. Nov 22, 2015 at 8:46 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    My truck is a v6 and also came with factory tow package which should include the beefed up alternator. My concern is if the truck will over charge. Anyone know about the alternators voltage regulator?
  3. Nov 23, 2015 at 9:18 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Your truck will be just fine - my concern is those smaller batteries can be damaged by charging too quickly - AGM batteries are sealed, and too rapid of a charge will cause gassing and pressure build-up within the case. Charging with your truck will give it about 14 - 14.4v at whatever amperage it takes. I would advise against it, since you'll have no control over the charge rate.
    Jimmyh likes this.
  4. Nov 23, 2015 at 7:57 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    ^ That just about covers it.
  5. Nov 23, 2015 at 10:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What landphil said. Get a proper charger and use that instead.
  6. Dec 1, 2015 at 8:34 PM
    Taco47
    Norcal
    2016 2TR 5-Speed
    Thanks for the info landphil
