Can I salvage any of my parts from my 04 to a 97
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rez taco, Mar 3, 2020.
  1. Mar 3, 2020 at 8:08 PM
    Rez taco
    Rez taco [OP] New Member
    Are the 3.4 V6 the same in a 97 and 04 ? And can I transfer any other parts from my 04 to the 97
  2. Mar 3, 2020 at 8:21 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    All the main componants of the engine are the same. The throttle body will be different and maybe a sensor here and there.
    Suspensions are pretty much the same. Front is identical... rear... the leafs are different between 97 and 04.
    Trans is different. T-case is (most likely) different (assuming your 97 is plsin J-shift... thst is different than your 04)
    Is that kind of what you're asking?
  3. Mar 3, 2020 at 8:27 PM
    Rez taco
    Yes that’s exactly the info I was looking for, I haven’t bought a 97 yet I’m looking at one tomorrow I’m just trying to find what year Tacoma I would need to buy to salvage as many parts off my rolled 04, thank you for the info
  4. Mar 4, 2020 at 2:12 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Myself I would look closer to your 04 that way more goodies can be used.
    Then it depends just how much can be used on another vehicle.
  5. Mar 4, 2020 at 7:35 PM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    If you want to be SURE most parts will swap, buy an 03-04. If you want to be VERY close, buy an 01-02. If you want to be acceptable, buy 95.5-00.
    El Taco Diablo likes this.
  6. Mar 4, 2020 at 8:34 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You can swap your grill and front fenders, too.
    If your 04 frame is good, you don't need to worry *as much* about the frame rust thing since you can more than likely swap the frames too, with some minor tweaking here and there... as long as you get the same body style.
  7. Mar 4, 2020 at 8:38 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    To make that work you need
    Hood
    Fenders
    Core supports (upper/lower)
    Grill
    Headlights
    Turn signals
    Headlight fillers
    My son is looking at doing the 2001-2004 Tacoma swap on to his 96 4 runner. :D
  8. Mar 4, 2020 at 8:44 PM
    jbrandt
    Justin
    Yeah, I neglected a few things. Should'a just said "the front end"
    Those 4Runner/Taco swaps just don't sit right with me. It's kinda like (tho not nearly as bad) as those VW/Rolls Royce franken builds. My brain doesn't compute.
    Fuergrissa likes this.
  9. Mar 4, 2020 at 8:46 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lmao! I know what you mean.
    I like the Tacoma swapped on to T4R... not the other way.
    jbrandt[QUOTED] likes this.
  10. Mar 4, 2020 at 8:50 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Also @jbrandt his T4R was in a front end collision and is salvage title. The hood is a replacement, the fenders are (slightly) creased, grill is damaged and core supports are creased as well.
    I would tell him not to do a Taco-runner if a bunch of the parts weren't going to need to be replaced to make everything straight anyway.
  11. Mar 4, 2020 at 8:52 PM
    jbrandt
    Justin
    Yeah, makes sense.
  12. Mar 5, 2020 at 12:20 PM
    1997tacomav6
    Denver
    The 1995-1997 actually is different in the front area. They change the headlights, grill, bumper mid year or so.
    There is actually more room in between the radiator and the front bumper after 1997.
    That area is different that I know
    Most other parts can be swapped,
    MAF housing and style will be different,
  13. Mar 5, 2020 at 12:35 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Not really sure what you're sayin here.
