Can I swap front end and rear end differentials, axles and wheels from a 2000 ext cab into my 96?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98AmishTaco, Apr 7, 2023.
  1. Apr 7, 2023 at 2:10 PM
    98AmishTaco
    98AmishTaco [OP] New Member
    Larry
    98 Gree Reg Cab
    Can I swap front end and rear end differentials, axles and wheels from a 2000 ext cab into my 96 ext cab?
    Sorry, first post....
  2. Apr 7, 2023 at 2:12 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome To TW...without modifications?
  3. Apr 7, 2023 at 2:15 PM
    98AmishTaco
    Larry
    98 Gree Reg Cab
    Yes. Both are 4wd, both manual.
    I should add, the 96 has 3.58s, and it is too weak. The 2000 has 4.30s. Both are 2.7l 4 cyl.
    Laxtoy and HondaGM like this.
  4. Apr 7, 2023 at 2:37 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I *think* the only difference you'll find are the rear leaf springs. They moved the hangers. So you should be ok if you don't try to swap those. You're just thinking the whole rear axle housing, front diff + stub shaft + CVs? I don't see why that wouldn't work as long as they are both manual hubs or ADD..
    Wulf, Laxtoy, HondaGM and 1 other person like this.
  5. Apr 7, 2023 at 11:45 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Yes, parts are interchangeable, as stated above, only difference is rear leaf springs which sound like you aren’t swapping
    Wulf likes this.
  6. Apr 8, 2023 at 9:07 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    There were two styles of e-brake cables on the rears. One over the spring and one under. There has been no definitive year/model application other than the "under" spring set up seems to be found on the later years. Should be no big deal to swap if needed, just something to be aware of at the planning stage.
    Wulf likes this.
  7. Apr 10, 2023 at 8:13 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I am 99.85% sure it's 2003.5-2004 in conjunction with the updated throttle body.
    Wulf likes this.
  8. Apr 10, 2023 at 8:19 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Yep! I bet you'll find going to 4.30s well worth the gain in peppiness
