can I swap my motor with one from a sienna
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jayrizzzle, May 25, 2024.
  1. May 25, 2024 at 4:50 PM
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
  2. May 25, 2024 at 4:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Firn and calzonical[QUOTED] like this.
  3. May 25, 2024 at 7:10 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Okay... I'd definitely find out if it's the bypass leaking rather than a cracked block.
    BUT... if it is a cracked block it may not be the end of the world. There's a product called Silver Seal that's available... There are other products, but I'm not sure they work as well. Be sure to get the METAL FLAKES and not the other products that are made out of walnut shells. To do your job properly (as properly as a cracked block can be done) you need to disconnect the heater hoses and bypass the heater core. This is important, because you can plug your heater core with these block sealers.
    https://www.ebay.com/itm/276397768057?itmprp=cksum%3A2763977680570079a1a23fbe4dd7a3bd707618673838%7Cenc%3AAQAJAAABgP9d%2BMZSXlztIfYFu3kI%2B7ft0VcQix7rTrUVdiJwc2upzwLfM%2B2UEqu0ZqdXqu2qWe6up6s9MSEY%2BWikIwEh4xLkizL%2BG%2Fyhg6cdW4xfkbb75erVQBYYISNxGN1au%2BE0eJ778JYYSAyLJRupNiZky3B2UHpMsaEp7JRgW9fuueOszPlG9eCPE4mSzJx4EejjZE0v1xx3s4HgKujjhEB3s6ndCrkcGOqtQoK%2FuAvh3ybY2N3X7aPjTA65LImWEygR6QoiEDHaeQchzQEoqcRiAGwI%2BgmHr%2F5D1PmTURfb8jsI1KVpLKk3Ad%2BeMB3deexRyk9olRlC114t%2Fioh3axIbX4JydVISK50wHqVaMIVUkh1lDjqnDr3TrwYekgUIxXo3FXMUDtioK0XmGFGWGaq%2BPE18KzpcmTMBDoQ%2BjUdDk%2BbKad2jxhanhq10cIn15sd2vqiNqOXx2nX5VuO4vh9yII9ZPqGmotR3pAIdakmjuICMYd1%2BTu8mwkd1EvhbcjzOQ%3D%3D%7Campid%3APL_CLK%7Cclp%3A2332490&itmmeta=01HYSAE26A16Y8XBXCRFYXNPE0
    Then follow the instructions on the container. After you've driven the truck for a few hundred miles, do a complete radiator flush and only then reconnect the heater hoses.
    I've sealed blocks that were cracked with some good success, and ran the cars for years. I'd never sell one that was sealed this way, but at least you can run the truck and get good use out of it.
    TheWildMan likes this.
  4. May 25, 2024 at 8:27 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Thats crazy. Knew about for radiators but not on the actual block.
    Travlr[QUOTED] likes this.
  5. May 26, 2024 at 5:15 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Years ago I read about someone who did this with a VW Rabbit. VW engine #1 under the hood as per normal, VW engine #2 under the rear hatch.
    I remember reading about how it was ridiculously fast, and being 4WD with balanced weight distribution, actually handled well too.
    Bottom line, I’m 100% in favor of you doing this mod. 296HP to the front wheels, plus another 296HP to the rear wheels.
    The only downside is, the only thing that Taco will haul, is ass!
    Some inspiration for you:
  6. May 26, 2024 at 5:35 AM
    Trail_Limo
    Trail_Limo Well-Known Member
    G
    Land of fruits and nuts
    Turd Gen OR Limo
    b_r_o, wilcam47, Steves104x4 and 4 others like this.
  7. May 26, 2024 at 5:43 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What is stopping you from driving the truck? A small coolant leak is not a death sentence.
    Chew likes this.
  8. May 26, 2024 at 6:43 AM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    As I remember; Vw did this to a GTI for pikes peak back in the day. 2 engines, AWD...
  9. May 26, 2024 at 11:51 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    to properly come up with that diagnoses they would have had to remove the tranny to get a close look, did they do that?
    removing the tranny is how they replace the crossover pipe.
    if they did where are the pic's they should have taken.
    only thing i can think of is pink corrosion NOT near or under the crossover pipe, and again where are the pis's.
    are there any freeze plugs back there?
    if the so called crack is seeping oil then still, PIC from them
  10. Jun 28, 2024 at 10:45 AM
    jayrizzzle
    jayrizzzle [OP] New Member
    Jaden
    2016 Tacoma trd sport
    Hey everyone, just want you thank you guys for helping me throughout all of this. I took it to another shop and they also found the crack. The area in the aluminum was described as “porous” which possibly could be a casting issue. I don’t experience any other issues other than the truck can’t hold coolant for very long and risk overheating, I also believe there’s air in the cooling system due to this which attributes to overheating. Not totally sure what to do yet just found out yesterday
    Steves104x4 likes this.
  11. Jun 28, 2024 at 1:04 PM
    Firn
    Firn Well-Known Member
    White OR
    Wow, good luck.
    If it's a casting problem with the block itself I would try reaching out to Toyota NA. It may be unlikely but they may do a goodwill repair since that is a major issue that is pretty serious and is clearly a manufacture issue
    Chew and TS4x4 like this.
