Can I tow a 31ft trailer
Discussion in 'Towing' started by TACKOY, Aug 4, 2022.
  1. Aug 11, 2022 at 1:02 PM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    lol, no.
  2. Aug 11, 2022 at 1:02 PM
    kcuv
    kcuv Well-Known Member
    kcuv
    USA
    TRD Off Road
    test run and report back
  3. Aug 11, 2022 at 1:59 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I will be purchasing a travel trailer in due time around the same weight as yours, homework completed as well:thumbsup:. How long is the one you purchased out of curiosity?
  4. Aug 11, 2022 at 2:05 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I think the OP gave up on the idea already. But he also indicated he may just need to move the trailer around his yard. It would probably be fine just moving it to mow or something.
  5. Aug 11, 2022 at 2:22 PM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    It's about a 20' box and 24' stem to stern.
    Just installed a Hellwig Helper Spring on the squatty ass to reintroduce rake and resist the squat beyond level. This on top of Sumo Springs.
    10thMTNgrunt[QUOTED] likes this.
  6. Aug 11, 2022 at 3:36 PM
    10thMTNgrunt
    2013 TRD Sport
    Nice setup, I’m going with a double axle set-up as well and just under 22’ stem to stern. I’ll look into the helper spring/sumo springs you mentioned:thumbsup:
  7. Aug 11, 2022 at 3:54 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    There's a few ways to go about it but I started by adding the Sumos. Helped a little in how the ass end reacted but they aren't designed yo fix that issue. I'm planning to put the 6xxx Bilsteins up front and in back but don't want to raise the truck so high that I have to start worrying about ECGS, UCA's, LCA's, etc but an eventually switch over to Deavers leak pak may be my final fix.
  8. Aug 11, 2022 at 5:09 PM
    Wire4Money
    Wire4Money Well-Known Member
    Tim
    2024 SR5 4x4 long bed
    Test drive first. My Tacoma did excellent on the freeway, great in the mountains, but could not maintain 60 in the southern Nevada desert, there are very long slight grades. It didn’t have enough power/rpms in 4th, too much power/rpms in 3rd. Towing a huge box seems to be very subjective and varies with location.
