Can I trust this "OEM Ball Joint"?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spazjensen, Feb 2, 2025.
  1. Feb 2, 2025 at 10:20 AM
    spazjensen
    spazjensen [OP] Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    After reading over several threads I'm undecided about which ball joints to use? Read the mixed reviews of Moog and Mevotec, read the posts about just changing LCAs, and how OEM BJ's are hard to get.
    On Toyota Parts website I find this from my go to dealer for parts:Screenshot 2025-02-02 131305.png
    My question is this considered the OE ball joint? I like being able to grease ball joints, but if the aftermarket options are truly as bad as others make them out to be I'd just assume go with the OE, if that is fact what is listed here. I don't do any off-roading aside from the occasional hunting trail/road and even then it's only 2wd level stuff.
  2. Feb 3, 2025 at 8:36 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    The parts you are showing in your screenshot are NOT the actual ball joint itself. The parts in your screenshot are the small brackets that the ball joint attaches to on the knuckle side.
    If you like greasing ball joints then the OE models aren't for you anyways since they are sealed. Factory Toyota ball joints are superior to aftermarket equivalents.
  3. Feb 3, 2025 at 11:49 AM
    Peter603Taco
    Peter603Taco Well-Known Member
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    ^what he said
    43330-09510 is the part number for the "equivalent" OEM ball joint. Toyota only sells it as a Hilux part, its not listed for Tacomas but has been proven by many to be the same exact one. I tried ordering it from 3 dealers in the US that had it listed as available but they all cancelled my order and said they couldnt get it. I ended up ordering one on Ebay from the UAE for like 75 bucks that seemed legit and all is well. Others I saw got them from Japan too, there's a thread about it somewhere.
  4. Feb 3, 2025 at 1:30 PM
    spazjensen
    Here
    Thanks guys. After posting the thread I looked a little closer and called the parts desk this afternoon and they clarified what wi_taco is describing above. I want to use the OE joints if I can get them, but mine have the boots coming off and I'm not sure if that is because of the angle being placed due to the 3" lift or just being old originals (2006 220k miles).
    If the OE replacement will just to the same boot separation, I'm inclined to go with something that will allow for a better ball joint angle if you get what I'm saying. But the Moog BJ has such a huge shoulder that I'm concerned with being able to replace the Moog joint if I ever need to. Sounds like aftermarket BJs will inevitably need to be replaced, so I need to account for that.
  5. Feb 3, 2025 at 1:37 PM
    spazjensen
    Here
  6. Feb 4, 2025 at 8:30 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    I saw a cut down show and tell model of a Moog bj years ago. It displayed how they had a metal intermediate cup inbetween the bj and housing that others did not. Effectively creating better wear quality (makes sense?). Do they still do that? Dunno. Only some? Dunno. Have they gone chinesium? Maybe?
  7. Feb 4, 2025 at 8:42 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Sadly, today's Moog is but a shadow of the Moog so many of us grew up trusting.
  8. Feb 4, 2025 at 9:38 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    155K 2011 0rigional BJ's
  9. Feb 4, 2025 at 9:43 AM
    HWI
    HWI Well-Known Member
    North Florida
    2015 Tacoma TRD Off Road
    I wouldn't trust Moog any more than your generic autoparts store brand for most things these days. My Duramax on 35's blew through a set of Moog balljoints in less than 50k miles. Meanwhile, Mevotech TTX balljoints are going on 75k miles and still have zero play. I ended up replacing the OEM lower balljoints in my Tacoma with the Mevotech TTX ones as well. The only negative thing I have to say about them for the Tacoma is the grease fitting should be a 45, the straight one requires an extremely low profile grease coupler due to the proximity to the CV axle.
  10. Feb 4, 2025 at 4:23 PM
    spazjensen
    Here
    My original BJs, the ones I'm replacing, have 220k, 2006 model. And that was with the boot being separated from its seat the last eight or so years. I'm replacing with OE, hopefully, once they arrive. I wanted to be able to service/grease the joint like my uppers, but I just don't have the confidence in the aftermarket brands.
  11. Feb 10, 2025 at 9:42 AM
    spazjensen
    Here
    Straight from Japan. Just arrived today. $82 total for both from amayama. Took about a week once they shipped.
    Wondering if there is a way to put a tighter 'something' to hold the boot place at the seat since that's where mine separated at.
  12. Feb 10, 2025 at 9:50 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Nice! Looks identical to what I received both part and label.
  13. Feb 10, 2025 at 9:54 AM
    spazjensen
    Here
    glad to hear that. I was a small bit worried in the back of my mind. This is the first time I ever had to order anything overseas for a vehicle. Yours went in and functioned ok I take it?
    Just a note about amayama: while the purchase process is weird and leaves you hanging until they confirm availability for the final cost, i do like that they showed me three different OEM sources (one Japan, two UAE) and Japan was cheapest parts price. They also were very good about communicating via email with updates all the way from the order being placed, shipped/tracking (mine was DHL), customs, and "out for delivery" emails.
  14. Feb 10, 2025 at 10:58 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    There is not a single aftermarket lbj that can be greased that will last as long as an OE ball joint.
    Too Stroked likes this.
  15. Feb 10, 2025 at 10:59 AM
    gotoman1969
    What site did you use to order these?
  16. Feb 10, 2025 at 11:01 AM
    spazjensen
    Here
  17. Feb 10, 2025 at 11:11 AM
    RemAllDay
    RemAllDay Member
    2012 Tacoma TRD Sport DC LB
    6in Drop Bracket lift. 33x 12.5 x 20 Tire. 20 x 9 Black Rhino Wheels
    I am having the same problem with my 2012, need a new LBJ and the dealership wont sell me the part directly they say i have to order an entire LCA. Does the 43330-09510 Joint work for the 2012s as well? i would think the suspension is pretty much the same and amayana states this part will work for 1GRFE.
  18. Feb 10, 2025 at 11:42 AM
    Peter603Taco
    Peter
    New Hampshire
    2013 TRD Sport DCLB
    Yeah everything went smoothly and has felt good for a couple thousand miles the past month
    Yeah 05-15 4wd should all be the same as far as I know. I think 3rd gen's as well, and possibly 2wd but I'm not sure.
  19. Feb 10, 2025 at 11:43 AM
    spazjensen
    Here
    i have an 06' 2TR. I can't say it would for sure fit. But if factory control arm part number matches between the two (06' Prerunner vs 12' Prerunner) then it should be the same LBJ
  20. Feb 10, 2025 at 12:01 PM
    RemAllDay
    RemAllDay Member
    thanks i think im going to give it a go, I want to use OEM parts but the dealership would only sell me a $600 complete control arm. You would think for a part that has a known failure they would sell OEM parts to kill the aftermarket competition.
    I have one bad side with a good squeak right now so i think 42 dollars is worth taking the chance
    Peter603Taco likes this.
