Can i Use 75W-90 gear oil instead of 75W-85 for the diffs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stickbug1, Mar 16, 2024.
  1. Mar 17, 2024 at 5:02 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  2. Mar 17, 2024 at 6:31 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    $99 seems reasonable for dealership prices. However I got the oil to do both from Walmart for under $65 and the transfer case oil for $25 from Amazon. Stuck drain and fill pugs suck so I understand leaving that to a pro.
    captrussia253 and bulalo[QUOTED] like this.
  3. Mar 17, 2024 at 6:36 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    It's made by Warren, so good stuff. Their Supertech oil is also made by Warren. Run both with confidence.
    Taco_mike73[QUOTED] likes this.
  4. Mar 17, 2024 at 6:48 AM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    What part of the country are you in @stickbug1 ?
    Reason I ask...
    I'm in Phoenix AZ. Hotter than the hinges of hell here for a solid two months and just toasty the rest of the time. I tend to cheat towards thicker oil's here because of the higher temps. Fluids that get changed multiple times a year like engine oil get thinner in the winter an thicker in the summer but never a wild swing just bumping it up one rating or down.
    The difference between your two oils is negligible but running 75W-90 gear oil in Manitoba, Canada will be a more noticeable difference than running it in the Sahara Desert.
    So it's a "YES! But..." kind of answer.
  5. Mar 17, 2024 at 8:58 AM
    Taco_mike73
    York, PA
    I know. I'm using the motor oil too. I actually started using Shell Rotella gas truck cus I got a bunch of quart bottles on clearance not long after I get the truck new then switched to super tech. I noticed no difference in how the engine runs so I got full confidence in the gear oil too.
    A few guys in oil threads question how good it is. I'd like to send a uses sample to Blackstone to prove it but this time I forgot to take the sample and had my drain pan mixed with gear oil.
    Only problem with getting the ST gear oil is my local store shows it in stock online but it's never on the shelf. I ordered mine for pickup then it got changed to free home delivery.
    Delta09[QUOTED] likes this.
  6. Mar 17, 2024 at 12:05 PM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    Amazon carries Redline if you want to keep running 75w85, but it’s not cheap.
  7. Mar 17, 2024 at 12:40 PM
    DesertIceCap
    DesertIceCap Well-Known Member
    Gasoline Forever
    Why are you using 90 instead of 85?
  8. Mar 17, 2024 at 4:27 PM
    Redsquirrel
    Redsquirrel Well-Known Member
    I just changed mine with 85 140
  9. Mar 17, 2024 at 4:41 PM
    Taco_mike73
    York, PA
    Because there is very little difference between the two in viscosity. 90 is only a bit thicker at operating temp than 85. They spec 75w85 most likely for a tiny amount of fuel economy to meet government regulations. 75w90 is a more common gear oil so there the benefit of it being cheaper and much more available.
    bulalo likes this.
  10. Mar 17, 2024 at 6:56 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    And I noticed in cab is much quieter . Can’t hear the diff howl now
    GTGallop and Taco_mike73[QUOTED] like this.
  11. Mar 17, 2024 at 7:07 PM
    TacoTuesday1
    SD CA
    that’s easy. If you want a challenge tell us how to replace the clogged manual trans breather atop the bellhousing and relocate it.
    3JOH22A[QUOTED] likes this.
  12. Mar 17, 2024 at 7:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^You'll need to consult an endangered species (manual trans) specialist for that one!
  13. Mar 17, 2024 at 8:17 PM
    SpeySquatch
    2016 TRD OR DCSB
    I love how everyone thinks Amsoil is super expensive. Been running 75w-110 for years (because I tow during the summer). If you subscribe to an Amsoil membership you get 25% off all of anything you buy for 6 months.
    out of all the oil brands I’ve used Amsoil ALWAYS changed the cleanest (noticeably).
    Get good lubes, especially if you like peace of mind and driving your rig hard
    Inyo_man and jerrybear like this.
  14. Mar 18, 2024 at 1:24 AM
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
  15. Mar 18, 2024 at 4:49 AM
    #35
    Taco_mike73
    York, PA
    I didn't buy new crush washer gaskets. I just re used the original ones. They don't seem to be leaking at all. I don't think I would reuse them again though.
  16. Mar 18, 2024 at 5:40 AM
    #36
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
  17. Mar 18, 2024 at 7:11 AM
    #37
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The fact you have to subscribe to an oil membership is :crazy:
  18. Mar 18, 2024 at 11:33 AM
    #38
    SpeySquatch
    2016 TRD OR DCSB
    not if you buy $100+ worth of products
  19. Mar 22, 2024 at 5:57 PM
    #39
    stickbug1
    stickbug1 [OP] Member
    Anyone know the orientation of the crush gasket for rear diff drain and fill ?
  20. Mar 23, 2024 at 1:10 AM
    #40
    RicerRabbit
    RicerRabbit Well-Known Ricer
    '22 White TRD Off-Road DCSB Manual | '03 Lancer Evolution
    Itz JDM tyte, yo!
