Can i Use 75W-90 gear oil instead of 75W-85 for the diffs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stickbug1, Mar 16, 2024.
  1. Mar 23, 2024 at 1:36 AM
    #41
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Am I just tired or is that backwards?
    GTGallop[QUOTED] and SpeySquatch like this.
  2. Mar 23, 2024 at 10:01 AM
    #42
    SpeySquatch
    2016 TRD OR DCSB
    Crimped side facing away from diff (towards rear of truck)
    girMobi likes this.
  3. Mar 24, 2024 at 10:07 AM
    #43
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    Lower winter temps cause lubricants to thicken and slow. Using a thinner in the winter lets it flow easier.
    Higher summer temps cause lubricants to thin and flow faster. Using a thicker in the summer lets it retain some viscosity without getting too thin.
  4. Mar 24, 2024 at 10:59 AM
    #44
    BillyE
    BillyE Well-Known Member
    This used to be common. I guess OCIs now usually span multiple seasons. But we used to have summer oil and winter oil, not that it really made much difference I suppose.
    GTGallop[QUOTED] likes this.
  5. Mar 24, 2024 at 11:11 AM
    #45
    jerrybear
    jerrybear Well-Known Member
    17 off-road
    90,000 on the truck. 75-90..
    Taco_mike73 likes this.
  6. Apr 12, 2024 at 4:53 AM
    #46
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    It's been nearly a month since I changed my front and rear diffs with SuperTech 75w90 full synthetic and put Redline MT-LV in the transfer case. Nothing has exploded yet. I'm almost convinced that the rear diff is actually a little quieter now. The MR-LV is a 70w75 oil so it should be slightly thinner in cold weather than the OEM 75w oil toyota sells in that can that should be gold plated for the price they ask. That should help it in the winter when I want to shift into 4 wheel drive to drive in the snow and nothing is warmed up yet.
    Smacky2020 likes this.
  7. Apr 12, 2024 at 5:00 AM
    #47
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Nice, I'm going to do my diffs soon too but leave TC alone for a few more thousand miles. How many miles you got on yours now?
  8. Apr 12, 2024 at 5:26 AM
    #48
    Taco_mike73
    York, PA
    I have almost 31,000 miles now. I was just a bit over 30,000 when I did them. I actually did it with other 30k service stuff that was in the maintenance schedule like oil change, engine air filter and such.
    I really think I could have put off the transfer case longer too but I was under there and had an acceptable oil on hand, it was a good weather day too so I just got her done. these fluid changes were really easy too. I'm sure I save a few hundred doing it myself
    jerrybear and Smacky2020[QUOTED] like this.
  9. Apr 12, 2024 at 1:45 PM
    #49
    girMobi
    girMobi Well-Known Member
    2020 TRD OFF
    RCI, Martin, Vort and Irken tech
    Some of these oils are rated differently because different additives are used to achieve the posted viscosity. If those additives aren't compatible with the seals and metal in your case, you may find yourself with a bigger bill.
  10. Apr 13, 2024 at 11:53 AM
    #50
    Kobe_lee24
    Kobe_lee24 Well-Known Member
    SOCAL
    2020 Tacoma TRD OR
  11. Apr 13, 2024 at 1:12 PM
    #51
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    bulalo[QUOTED] likes this.
  12. Nov 20, 2024 at 9:06 PM
    #52
    TacoTin0350
    TacoTin0350 Member
    Not sure if this helps anyone but this is the service paper I recently got from the dealership...269 canadian for 4wd service assuming that's the fluid exchange for differentials and transfercase...as easy it is to work on, it's seems it's almost worth it to let the dealership do the work
  13. Nov 21, 2024 at 2:57 AM
    #53
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    4WD service could mean a mere inspection at a stealership. My dealer was almost $600 for the diffs. I didn't do it there but that's what they wanted to do the front and rear diff. I wound up doing the rear myself and having my mechanic do the front when I had the oil changed. I supplied the front diff oil. Total cost was under $120. I only go to the dealer so they can inspect that my front floor mats are installed properly.
    TacoTin0350[QUOTED] likes this.
  14. Nov 21, 2024 at 3:57 AM
    #54
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    I'm not sure they can do that correctly. That will be $100. We have Toyoya trained techs that do this.
  15. Nov 21, 2024 at 5:57 AM
    #55
    TacoTin0350
    TacoTin0350 Member
    Yea i told the guy ill do it another time but I'll call at some point this week to ask what that actual service entails because you're right it could actually mean that it's only a taste test haha.
  16. Nov 21, 2024 at 6:57 PM
    #56
    TacoTin0350
    TacoTin0350 Member
    Phoned the service department i usually go To get extra clarification on what the 4wd entails, and it is a front, rear, and transfercase fluid change for 268 canadian +taxes. I phoned another toyota and they were quoting triple that price for all 3. I think 268 cad is a pretty decent deal.
    rndsommer40[QUOTED] likes this.
