Can I use a 7.5 inch tire on a 17x7j rim?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by barnstormer399, Apr 9, 2023.
  1. Apr 9, 2023 at 1:02 PM
    barnstormer399
    barnstormer399 [OP] Well-Known Member
    2007 DCSB
    I have an 07 DCSB 4x4 a/t that I bought used, already had trd pro wheels and BFG At t/a K02 tires (lt265 70r17) that were aging anyway. Ran over a bolt somewhere, so I replaced all 4 with Falken wildpeaks.
    Also noticed that the spare is still the orig OEM 16 inch and the wheel is rusted almost through. One of my K02 still had good tread, so I just need a wheel. Found. The below model on FB marketplace, can I use it with the old tire? Says it's a 7 inch width, but I thought these tires were 7.5?
    https://www.*****************.com/o...uot-6-spoke-flat-black-wheel-oem-ptr5689210f2
    PTR56-89210-F2 TOYOTA TRD PRO 17" 6 SPOKE FLAT BLACK WHEEL OEM - TOYOTA (PTR56-89210-F2)
  2. Apr 12, 2023 at 10:54 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    I'm assuming you replaced the 265/70/17 BFGs with the same size Falken Wildpeaks? If so, according to the specs on Falken's website you should be fine. SL rated can fit 7-9" wide wheels, E rated can fit 7-8.5" wide wheels.
    https://www.falkentire.com/wildpeak/at3w
