Can I use any of these components?
Discussion in '5 Lug' started by Mr.Schertz, Dec 29, 2012.
  1. Dec 29, 2012 at 10:27 PM
    Mr.Schertz
    Mr.Schertz [OP] Well-Known Member
    TEXAS
    08 single cab 4banger
    tint,removed badges,custom letter chop and rephrase
    I was offered this locally. Can I use any of this for my 2008 5 lug?
  2. Dec 29, 2012 at 10:49 PM
    Nixinus
    Nixinus Well-Known Member
    Use what?
  3. Dec 29, 2012 at 10:51 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Possibly :notsure:
  4. Dec 29, 2012 at 10:52 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2010 Double cab 4X4 TRD Sport with JBL
    Redline Tuning hood struts, tinted windows, FX-R HID projector retrofit headlights, AMP power steps
    Potato?
  5. Dec 29, 2012 at 11:17 PM
    Nixinus
    Potahtoe?
  6. Dec 29, 2012 at 11:18 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    or pothibly tomato?
  7. Dec 29, 2012 at 11:19 PM
    Nixinus
    Well played sir!
  8. Dec 29, 2012 at 11:57 PM
    nagorb
    nagorb Temp mod
    Auburn Alabama
    2001 dbl cab 4x4
  9. Dec 30, 2012 at 12:14 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Bangladesh!
  10. Dec 30, 2012 at 1:13 AM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not knowing what, my guesses would be:
    5 lug Taco is not the same bolt pattern as 5-lug Tundra... the wheels won't fit.
    5 lug Taco suspension is completely different from the 6-lug... prerunner and 4x4 suspension parts will not fit... though you can use prerunner/4x4 rear leaf springs to lower your 5 lug an inch or so.
  11. Dec 30, 2012 at 7:58 AM
    Mr.Schertz
    TEXAS
    Dammit! LOL...I goofed up that post. I am ordering a spacer and add a leaf kit for my five lug and want to upgrade the shocks and struts. Here is what I have available to me locally."If you're interested I have the stock TRD off road shocks off of my 2010, the stock upper control arms and a "ready lift" leveling kit. I also have the stock springs for my truck. The stock shocks are the yellow bilstein ones. "
  12. Dec 30, 2012 at 10:06 AM
    brian
    Elizabeth City, NC
    Won't work.
  13. Dec 30, 2012 at 11:56 AM
    Mr.Schertz
    TEXAS
    the rear shocks will,correct?
  14. Dec 30, 2012 at 6:28 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    yes they will on a lifted 5-lug
  15. Dec 30, 2012 at 10:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay... see above.
    I don't think so.
    5 lug is SUA, 6 lug is SOA.
    Stock springs, that's already a 4-5" difference (longer on the 5-lug).
    Lifting the 5-lug with taller springs makes that difference even greater.
  16. Dec 31, 2012 at 6:24 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    the shock is of the same design. so it will work.
    how well it will work is a completely different story, though.
    ask ryry. i think he used them for a little while when his truck was all high and stuff.
  17. Dec 31, 2012 at 9:51 AM
    afd23a
    The Dynamo of Dixie
    I'm running 6 lug shocks on the rear of my truck right now. Once the truck is lifted the stock rear shocks of the 5 lug aren't long enough. Even though Readylift claims no shock replacement is necessary, there isn't enough up travel in them to accommodate the lift. I used stock trd bilsteins on the rear of my truck after installing the Fat Bob's lift. While the rear leafs are different, both 6 lug and 5 lug shocks mount below the rear axle. It may not be the best route (hell it's a spacer/AAL lift) but it so far it has worked fine for me.
  18. Jan 5, 2013 at 11:20 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    will they fit? yes but they do have a longer collapsed length meaning if you load up the truck it may bottom out the shock first before hitting bumpstops
