Can I use Bilstein's to raise my height with my current setup?
Discussion in 'Suspension' started by tonyfinchico, Nov 12, 2017.
  1. Nov 12, 2017 at 9:01 AM
    tonyfinchico
    tonyfinchico [OP] Member
    2016 Tacoma TRD Sport 4x4
    Spacer leveling kit in the front, add a leaf in the rear, 12 Volt Solutions auto start, rims and tires, shell
    So I have a 2.5” leveler in the front and the add a leaf in the rear.
    Can I use the bilstein shocks and still raise the height a bit?
    I am a complete novice to Tacoma’s.
  2. Nov 12, 2017 at 9:07 AM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Do you mean raising the front even higher than 2.5”?
  3. Nov 12, 2017 at 9:27 AM
    tonyfinchico
    Yes. If I get the bilsteins could I adjust the front and rear up more or not?
    Is it worth it to buy them or if I can’t adjust it up more should I buy a different shock?
  4. Nov 12, 2017 at 9:28 AM
    HSmith_11
    Hunter
    Madison, Va
    The fronts adjust but the tears do not. However, it’s not a good idea to go over ~3 I’d lift because it will wear down all of your suspension components because of how the independent suspensions works.
  5. Nov 12, 2017 at 9:31 AM
    tonyfinchico
    Got it. That’s what I was looking for. So if I wanted to go higher it would be a full on suspension lift?
  6. Nov 12, 2017 at 9:33 AM
    Friedtacolover
    Friedtacolover Well-Known Member
    Travis
    Ontario, Ca
    2017 DCSB Off Road 4x4
    my build tread: https://www.tacomaworld.com/threads/socal-no-shame-poser-build.513084/
    Take off spacers, buy maxtrac spindles. 4” lift
  7. Nov 12, 2017 at 9:34 AM
    HSmith_11
    Hunter
    Madison, Va
    Only for prerunners right? Not sure if OP is 4x4
  8. Nov 12, 2017 at 9:34 AM
    Friedtacolover
    Travis
    Ontario, Ca
    Well his profile says sport no 4x4 so ya only 2wd. I assumed he is 2wd
  9. Nov 12, 2017 at 9:36 AM
    tonyfinchico
    It’s 4x4
  10. Nov 12, 2017 at 9:37 AM
    eon_blue
    Azusa, CA
    True but I've found that some people in certain regions aren't even aware that the Tacoma comes in a 2wd model, he may not have put 4x4 there because he assumes all Tacos are 4wd. Some regions where it snows every year you see little to no 2wd trucks.
  11. Nov 12, 2017 at 9:44 AM
    Friedtacolover
    Travis
    Ontario, Ca
    Could you swap out springs for ome springs then add a 1/2” spacer for another 1” of lift? Assuming you have the 5100’s compatible with the springs leveling the front now
