Can I use Mobil 1 75W-90 LS for transmission oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shawn OT, Sep 21, 2019.
  1. Sep 21, 2019 at 2:37 PM
    Shawn OT
    Shawn OT [OP] Member
    Shawn
    2008 Tacoma SR5 Access Cab 4.0 6 Speed Manual
    I'm planning to change the transmission oil on my 08 4.0 6 speed manual. I believe 75W-90 is the recommended viscosity. I recently bought Mobil 1 75W-90 LS gear oil for the transfer case, and diffs and bought enough to do the tranny as well. The oil says is has a limited slip friction modifier added to the oil. Is this still ok to be used in the transmission, or should I go with something else?
  2. Sep 21, 2019 at 2:43 PM
    FJBub
    FJBub Well-Known Member
    Doug
    2010 Tacoma PreRunner 2015 Tacoma TRD Off-Road 2008 V8 4Runner
    RedLine MT90 is what you seek. Lots of guys run it in their manuals. I've used it in my FJ for 12 years. Now at 232K.
  3. Sep 21, 2019 at 2:48 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  4. Sep 21, 2019 at 2:58 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I'm pretty sure you do not want limited slip modifier in your MT.
    I have redline in my nissan, it shifts great. The first time i changed it i used some oil that supposedly met the spec and it was awful.
  5. Sep 21, 2019 at 4:11 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    LS gear oil is fine to run in mt's.
  6. Sep 22, 2019 at 5:56 AM
    Shawn OT
    Shawn
  7. Sep 23, 2019 at 9:07 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    The M1 75W90LS is GL-4 and GL-5 rated and is probably fine. I debated on using that in my 5spd as i had several quarts of it in the stash,
    but I went with the RedLine MT90 for ease of mind.
    No issues so far.
    Good Luck with it.
  8. Sep 23, 2019 at 10:35 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    If the transmission is not spec'd for LS fluid, I would not use it. I don't think it's worth the potential problems, which could be serious. So just spend the extra $25 and get the right product. You will eventually use the extra LS fluid for its intended application. I was told I can use LS fluid in my open differential but I don't think that means it's OK for all gearboxes.
  9. Sep 23, 2019 at 12:49 PM
    Shawn OT
    Shawn
    Thanks for all the input, I ordered Redline MT-90.
    FJBub likes this.
