Can I Use My Battery Charger With The Stock Inverter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WATacoRider, May 11, 2012.
  1. May 11, 2012 at 8:34 AM
    WATacoRider
    WATacoRider [OP] Well-Known Member
    TRD Sport 4x4
    I'm going camping. I'll need a way to charge up my boat batteries. I'm wondering if this will work?
  2. May 11, 2012 at 8:39 AM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Just plug it in and see if it works. It's not like your powering a mitre saw or anything.
  3. May 11, 2012 at 8:47 AM
    Goober
    Goober Earthlings are fun to watch!
    Utah - Why just have only one?
    '11 TRD Off-Planet AccessCab
    Output is 400 watts / 120v = 3.3amps. Should work.
  4. May 11, 2012 at 8:56 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Should work fine. That battery charger has a pretty low draw according to your picture, only 1.8A. Hell, my driving lights draw more than that!
  5. May 11, 2012 at 9:15 AM
    WATacoRider
    TRD Sport 4x4
    So if I'm only taking in 1.8amps and putting out 10amps with the charger.
    Is it possible to make unlimited power if I just start connecting a bunch of these chargers? :D
  6. May 11, 2012 at 10:07 AM
    Enzo
    Opie
    Bedford, Va
    2012 FJ Cruiser
    :D
  7. May 11, 2012 at 10:11 AM
    Pugga
    Massachusetts
    No, you have to understand how amperage and voltage interact. You can put in 1.8A and output 10A but your voltage is significantly reduced. (1.8A at 120 volts vs. 10A at 12 volts).
    I realize that most likely wasn't a serious question but it doesn't hurt to know the answer to it.
