Can I use Siri with Bluetooth through the Tacoma head unit?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by traylor1, May 4, 2024.
  1. May 4, 2024 at 7:01 PM
    traylor1
    traylor1 [OP] Member
    I have a shortcut set up to open my garage door, activated by pressing a button on my steering wheel and using Siri. It functions properly when I'm in my Highlander with the aftermarket receiver.
    However, in my Tacoma, it consistently triggers the Toyota voice prompt instead of Siri through my Tacoma's head unit, regardless of whether I'm using Bluetooth or CarPlay. And it never understands the command. There must be a setting causing this, but I can't seem to find it.
    Any suggestions would be helpful.
  2. May 4, 2024 at 10:02 PM
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    If you have a 2017+ you can use the phone up button on your steering wheel to engage Siri. You just hold on it. I’m not sure if it’s for higher trim levels but it works great on my 2017 TRD Pro.
    If you have a 2019 or older and you want to get even niftier, take a look at carsynctech.com as they have a wireless CarPlay module that connects to our stock decks. CarPlay natively uses geolocation and as you approach your home, the CarPlay Home Screen automatically pops your HomeKit garage door opener up and allows you to open it with a quick tap. This module also enables “hey Siri” which might help you as well.
    I just installed this module and it’s absolutely fantastic. $270 gets it done (once they’re back in stock).
  3. May 5, 2024 at 1:26 AM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    I have a 2021 , just push and hold the voice prompt button on the steering wheel triggers Siri
    poopshute likes this.
  4. May 5, 2024 at 4:13 AM
    traylor1
    this is what I have been trying to do, but it is the Toyota voice control and not Siri.
  5. May 5, 2024 at 4:16 AM
    traylor1
    Thanks for the help. I have a Sport, but will try this.
    I like that adapter, but mine is a 2021, so it doesn’t work for mine.
  6. May 5, 2024 at 7:14 AM
    vivid02
    Edwin
    SoCal
    OEM+
  7. May 5, 2024 at 7:31 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I think if you go into the car play settings through the vehicle's carplay screen (phone connected) then scroll to the bottom and there is a selection that will open up the carplay settings on the phone screen which aren't accessible without it connected to the vehicle and car play running, it will let you enable siri. My Rav 4 has a similar audio system and I seem to remember that setting, on mine it was already enabled from using it in my Tacoma which has a aftermarket system.
  8. May 5, 2024 at 5:33 PM
    traylor1
  9. May 5, 2024 at 6:58 PM
    poopshute
    Colorado
    Can you try holding your phone answer button on your steering wheel to see if that works? In my 2017, that’s the way I can get Siri to come up.
  10. May 6, 2024 at 7:18 AM
    traylor1
    Yeah, tried it. For some reason "Hey Siri" is the only thing I can find.
    I did see a video last night that I need to try. that shows there is supposed to be a button on the carplay screen that I should be able to work with also when carplay is working. However, that doesn't help with Bluetooth.
  11. May 7, 2024 at 1:49 PM
    poopshute
    Colorado
    Bummer. I'm not sure how the 2020 CarPlay systems work but for the 2017-2019 year, holding down the call answer button for a second engages Siri. On any CarPlay unit, if you hold down the screen layout button in the bottom left corner, Siri will activate as well. Best of luck!
