Can i use these shocks??!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chanes8cwu, Dec 7, 2016.
  1. Dec 7, 2016 at 9:55 PM
    chanes8cwu
    chanes8cwu [OP] Well-Known Member
    Joe
    Ellensburg, WA
    2012 DCLB Tacoma 4.0L
    fox 2.0s i want to put in the rears. 29" extended, 19" compressed. Will these work with 2-3" lift in the back? Im a newbie to shock lengths. I believe these were intended for a jeep. Any info helps!!!!
  2. Dec 7, 2016 at 10:03 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Part # may help others out.
    10trdtaco likes this.
  3. Dec 8, 2016 at 7:32 AM
    chanes8cwu
    Joe
    Ellensburg, WA
    The guy selling them doesnt have the part number but says they are for a '15 jeep rubicon with a 5" long arm kit. I think they are for a 6" lift
  4. Dec 8, 2016 at 7:34 AM
    JadedTaco
    JadedTaco Well-Known Member
    IA
    15 OR SSM (MT)
    Lift, tires, mats, blah, blah, blah...
    I believe those are too long.
    I'm running a 2.75" lift in the rear with Bilstein 5160's (14.22″ collapsed and 24.06″ extended).
  5. Dec 8, 2016 at 7:35 AM
    Large
    Large Red
    Since you don't have 10" of wheel travel in the rear, I would say go for it as long as they bolt up. Just bump it / strap it accordingly.
  6. Dec 8, 2016 at 7:42 AM
    JadedTaco
    IA
    15 OR SSM (MT)
    Curious. Wouldn't the 19" collapsed length severely limit the amount of uptravel?
  7. Dec 8, 2016 at 7:43 AM
    Large
    Large Red
    actually you might be right. But if you're crafty enough you could make new mounts and make them work, then again why spend the time / money and not just buy the shocks you need from the get go.
  8. Dec 8, 2016 at 7:46 AM
    Pigpen
    Dan
    Northwest Montana
    If you want those specs, why not get Bilstein B110s? Mine ride great.
  9. Dec 8, 2016 at 7:47 AM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I'd be concerned that they're too long to compress under load. My extended travel rear Fox shocks are 15" collapsed and I'm on Dakar springs. So I'm probably sitting somewhere around 18-19" with no load in the rear (blind guess). The true test is to go out and measure what your shocks are resting at with whatever springs you have on the rear.
  10. Dec 8, 2016 at 7:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    You'd have to put a shock hoop in to make them effective. I'd stear clear.
  11. Dec 8, 2016 at 7:55 AM
    Pigpen
    Dan
    Northwest Montana
    With extended bumps and brake lines, you'll be fine if they bolt up.
  12. Dec 8, 2016 at 8:03 AM
    JadedTaco
    IA
    15 OR SSM (MT)
    Not to derail the thread, but how much lift do you think you have in the rear with the Dakar + AAL after settling?
    I was wondering if I should have added the AAL in mine.
  13. Dec 8, 2016 at 8:05 AM
    Pigpen
    Dan
    Northwest Montana
    with at least 400 pounds in the bed (probably more) My center of hub to fender measurement is 25"
  14. Dec 8, 2016 at 8:06 AM
    Pigpen
    Dan
    Northwest Montana
    There was zero settling with the AAL
  15. Dec 8, 2016 at 8:06 AM
    JadedTaco
    IA
    15 OR SSM (MT)
    Ahhh... added weight. Gotcha. Thank you.
    Sorry, OP. Back on track.
  16. Dec 8, 2016 at 8:10 AM
    Pigpen
    Dan
    Northwest Montana
    It's relative. If you have springs that increase your ride height compared to stock, not necessarily.
  17. Dec 8, 2016 at 12:21 PM
    chanes8cwu
    Joe
    Ellensburg, WA
    I was under the impression that you would need to reweld the shock mounts and straps with bump stops. I will stick with my 2.0 sway a way race runners. Thanks for the feed back everyone.
