Can I use this aal from toytec?
Discussion in 'Suspension' started by KaliTaco, Jan 20, 2011.
  1. Jan 20, 2011 at 10:43 AM
    KaliTaco
    KaliTaco [OP] Well-Known Member
    I have a rear tsb done with 1 1/2 inch block right now. Want to lift it more. Will adding the toytec 1 1/2 aal for tsb work with the block still? So tsb, aal toytec, and block = 3.5 inch lift for the rear.
  2. Jan 20, 2011 at 1:22 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    yes it will work but it will ride terrible and might give you vibrations.
  3. Jan 20, 2011 at 6:29 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It will work but you'll need longer shocks. I think you'll also need extended brake lines.
  4. Jan 20, 2011 at 6:31 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    take the block out and get a 2" aal
  5. Jan 20, 2011 at 6:45 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Just take the block out and put the AAL in.
    I'm running TSB springs plus 1.5" wheeler's AAL and it's a-ok.
  6. Jan 20, 2011 at 7:01 PM
    95.5 taco
    95.5 taco Greenhorn
    Kyle Osborne
    Cochran GA
    95.5 taco 3" lift 33" BFG KM2s
    3" lift, 33" BFG KM2s, alot more to come soon!!
    x3
  7. Jan 21, 2011 at 1:09 AM
    KaliTaco
    If I take the block out and do aal then the back would be about a 2 inch lift with my tsb. I'm trying to get a 3-4 inch lift to match the spindles and billys at .85 setting.
    If I do allpro pack I would still have to get 1 inch block. But with this it will cost me 400-450. Aal from toytec for tsb and using my original parts would be less then 100.
  8. Jan 21, 2011 at 3:16 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    with the block out and a tsb pack and a 2" aal you will be right at 3 "
  9. Jan 21, 2011 at 4:34 AM
    jandrews
    Woulda put me at about 3.5" (I got 1.5" out of my TSB springs), but I understand most people settle to more around an inch difference.
  10. Jan 21, 2011 at 4:55 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    :eek: was that a fat joke:eek:
  11. Jan 21, 2011 at 5:00 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Wouldn't stack lifts in front or back, call me crazy........I won't deny it:D
